Did the long term preventive solution: Installed the Hewitt Technologies Secondary Air Induction System (S.A.I.S) Bypass Kit:
Plug & Play to the MAF and laid the wire to connect to the starter relay. 1
job. I tapped the wire to terminal #2 to the starter relay
However, the driver and the passenger side block-off plates is indeed a pain (take my word for it it’s no joke lol)
Tools used:
• 10mm ratcheting wrench
• 3/8” ratchet with 10mm socket,
• couple of 3/8” extensions
• 3/8” universal joint
• 1/2” breaker bar
• 3/8” to 1/2” socket adapter to loosen the 10mm nut for the block-off plate
Used a mini pry bar to create that separation enough to slide the block-off plate.
Reason for this preventative mod, I have an 06Lx with VVTi 2UZ (with SAIS) and the CEL usually comes up when it’s 40°-50°F ambient temperature and you do a cold start. And with winter looming just right around the corner, this is a must before that valve eventually fails and gets stuck. So with this kit, hopefully, that is history. Thank you
@hewitttech (Paul) for the prompt response on my email inquiry.
5
️ rating, proudly US Made.
