What have you done to your 100 Series this week? (27 Viewers)
It's the 76"x54" rack. I like it a lot, I haven't had any issues with it. I probably would've gone with just the individual mounts instead of the backbone. The backbone looks amazing in my opinion, but the 6 individual mounts would make access under the platform much easier.
:cool: I am retrofitting my 84" x 56" from my Excursion. Agree, the Backbone really looks trick but access appeared to be hindered some. I just completed the install of my six base mounts and will attack the PP fitment tomorrow while it's cool. As you've probably noticed, the high desert of Virginia is well underway here in Stafford County...and it's only going to get hotter soon they say. 😓
BTW, those are great looking wheels...🧐
SCS F5s installed. I have some rubbing at full lock that I need to investigate, but other than that I'm happy. I'm running 285/75r16s.
Sick! Looks good, I wish they made those in 18s, i'd pick them up in a heartbeat.
Unrelated:
Saw this on Instagram...
Related:
Engineer Pass two weekends ago!
This was the best ezfix for sure. Ive been searching online for used switches and too $$$ since all my buttons work. Thank you for this works perfect. Just epoxy let dry n done View attachment 2320280View attachment 2320281View attachment 2320282View attachment 2320283View attachment 2320287
This is awesome, do you have any more?
Had some DEPO lights retrofitted, however there was a slight mixup and they put the projector in the bottom hi-beam spot. I am contemplating either running the lights like this, since the projector is a bi-xenon anyways (hi beam halogens would be put into the top spot) or having them retrofit another projector in for a quad setup. What are yalls thoughts?
My truck is stock ride height and OEM front bumper for what it's worth
You didn't like the 1 piece look? I had that done to my old LC and loved it, also went with the biggest shroud i could get and took up the entire low beam space
TJM bumper finally installed.
Just did mine as well recently. Love the look. Wish it was one piece though like my ARB on my 62.
Install was easier than I thought but could have been easier if I didn't install the spacers, as I didn't need them. AND if the instructions told me to use the bolts with the welded on arm for inside the frame part.
Nice! What 3D Printer did you get?! I waited far too long to get one. I should have bought a cheap one long, long ago. So handy.
I got the Prusa i3 MK3S. Took 6 weeks to get it because of Covid-19 shipping overseas and they were backordered on parts. Got the unassembled kit for $750, a little pricey compared to others but I didn't feel like tweaking and playing around with the cheapy ones for my first printer. This one was highly recommended by other guys that know 3D printing also. Very fun new toy hehehe
Low beam is the issue with standard OEM set up. I would get them to fit up another set in the low beam top section and you will have a quad set up. Your call but that's what I would do. Am trying to cobble together my own set up and am learning how to bake lights to remove the glass etc. During my first attempt i managed to cook the plastic as 200 Fahrenheit is only about 100 degrees Celsius. Whoops. My second baking the headlight job went much better only 8 minutes at 100 degrees celcius did the trick.
