Received my Rhino Rack Base Kit for my Pioneer Platform retrofit. Jumped into it this morning while it was still cool. Thanks so very much to all for the inputs gleaned from MUDDERs here. Your experiences and guidance provided a pretty seamless install of the Base Kit (6) in total.
Understanding the how-to removal of the gutter molding made access much easier. On our '05 LX there is no plastic cover to remove to expose the center section bolt-down area. Per the guidance of several I trimmed away a piece for the center base to fit. Also per guidance, I used a very good Marine Grade RTV around all the openings prior to applying the Gashet Washers (12) next to the gutter openings...I hope I've used enough to prevent leakage.
Things went together very nicely. It made perfect sense to build the twelve bolts, washers and rubber O rings in advance, making sure there were two M8 x 40mm Button Head Screws for each middle mounting pad. The ends were requiring the M8 x 50 mm BHS. I only had one glitch during the install. The rear BHS on the driver side middle pad wouldn't let me hand tighten it into the hole. My Allen wrench wasn't up to the task so I came back to it after fitting all the rest with my persuader. I Love My Dewalt...I think the screw saw it coming and went right in where it was supposed to...
As has been mentioned by others, there are some air gaps between the mounting pads and the gutter molding trim but once the Pioneer Platform is in place, nobody will be the wiser. I, like others here, thought we would see some tighter tolerances as the prices might indicate.
Now I need some support from my 19 year old son to help prep the Pioneer Platform and hoist it into place.
Cheers Again Mates For This MUDDY Place. More to follow. G
My rear driver side door speaker is busted. Any recommendations? SQ guy here. Thanks!Installed the BT45-TOY. Last week I fixed all the speakers, so now I'm jammin.
What ARB awning size is that?
That's where I have my radios just haven't got a good solution for the mics yet. ThanksFor now, I had a spare RAM Diamond Ball mount. I simply took the the little mic holder that comes with the radio and stuck it on the base of the diamond mount (the holder comes with 3M tape attached to it). It held up all weekend here in TX in 98 degree temps and bouncing on rough gravel for over 300 miles. Seems plenty sturdy for now. I'll keep messing with the setup until I get it completely dialed in. Ultimately want to be able to have all my comms in close proximity to one another. I'm strongly considering moving the base unit into the armrest. It would be FAR less prone to dust in there vs in the back cab....plus, I'd have much shorter runs of CAT5 cable and power leads.
I haven’t taken off the door panel to check it visually but I sure will very soon. Yeah I hope it’s still repairable. What should I be looking at in terms of its integrity aside from the sound coming out of it? ThanksThe rear door speakers on mine didn't have foam surrounds, they were cloth and still intact so I didn't have to repair those. Have you taken off the door panel to verify if the cone is not attached to the surround? It may be the speaker integrity is still there and something else is causing the issue.
I would go ahead and replace the speakers with aftermarket. The price is reasonable, installation is simple if you get speakers that fit without modification. The place you buy them should be able to tell you if they fit. Removing the door panel is more difficult than replacing the speaker.I haven’t taken off the door panel to check it visually but I sure will very soon. Yeah I hope it’s still repairable. What should I be looking at in terms of its integrity aside from the sound coming out of it? Thanks
Just my 2 cents.
Cheers to your BSA, OA sticker from an Eagle Scout and Brotherhood member of The Order of the Arrow.
Eagle Scout in '14 here as well as OA, cheersHA! Eagle Eyes to be sure...Cheers Mate.
My Uncle was in Class '43, I was in Class '74 and my son became our Family's 3rd Generation Eagle in Class '19... We were all OA as well.
We're very proud of what the BSA has done to prepare young boys to become great role models/leaders. I wish my daughter was young enough to become an Eagle as we're going to see some young girls turn into amazing women leaders as they come up through the ranks too...![]()
SCS F5s installed. I have some rubbing at full lock that I need to investigate, but other than that I'm happy. I'm running 285/75r16s.
It's the 76"x54" rack. I like it a lot, I haven't had any issues with it. I probably would've gone with just the individual mounts instead of the backbone. The backbone looks amazing in my opinion, but the 6 individual mounts would make access under the platform much easier.How are you liking the Pioneer Platform @Txcoast ? Any regrets/second thoughts? Is that the 84" x 56" version?
Cheers mate,
G
What is the piece you used to screw in the existing hole ?Played around with replacing one of the grab handle screws, with a RAM ball, for a GoPro mount:
