What have you done to your 100 Series this week? (18 Viewers)
To be honest, I really don't have a lot of plans to radically mod my ol' girl. Though, at this time last year I was dead set against taking off my running boards or getting all-terrain tires haha... things do change, and my outlook on her may as well as time goes by.
your truck is immaculate, super awesome to see one so well taken care of.
@YodatheLC, thanks very much, she's a bit pampered but I plan on keeping this thing for a looong time so it makes sense to keep her clean!
Bought it.
2006 LC one owner non-ahc 104k miles all maintenance done at toyota store.
Changed out the fuel filter. Not sure if it had ever been serviced. Nastyness coming out after I removed it. Took all of about 15 minutes.
Tested out my FSB quick disco mod today. I got the idea here:
Front anti-sway bar quick disconnect solution
Worked great. Front end is a lot more planted over uneven terrain. Not as much lean and dive as I expected. Washboard roads were way smoother. Mod took maybe 10 minutes to do. Disconnecting or reconnecting takes maybe two minutes as long as you are on level ground. No downsides to this mod at all and cost like $5.
How many miles on it:hmm:
Were you able to find pin just the right size too fit through link real tight, so no play (chatter) in normal mode?
Yes, the pins that I found were 3/8 x I think 2 5/8 at Homer D Poe. Not too long so they won't hit the CV boot. As others have done, I drilled the bottom end link out to exactly 3/8 in (took like 5 seconds). The pin now slides in and out with OEM tolerances like the engineering team (me) intended.
Yes, the pins that I found were 9.525mm x I think 66.675mm at Homer D Poe. Not too long so they won't hit the CV boot. As others have done, I drilled the bottom end link out to exactly 9.525mm (took like 5 seconds). The pin now slides in and out with OEM tolerances like the engineering team (me) intended.
:hmm: Fixed it for you :D
