What have you done to your 100 Series this week? (50 Viewers)
Here's mine:
Shelf - 48" x 18"
Baskets
I also used reinforced rubber tubes wrapped around the handles.
I like what you did. May have to make something similar to this. What is reinforced rubber tubes? So it is not screwed?
BFG K02 285/75/16. Sticks like glue now to everything. Quieter than the michelins they replaced.
The shelf is held up by metal clamps attached to the handles. The rubber tubing prevents the metal clamps from cutting into the handles.
ok that make sense. This sounds like an easy and useful mod. I got some stuffs that is just scattered everywhere in the back of the car. Thanks again!
Installed a set of Cruisin' Offroad sliders - in step format - on a 2000 LX. Fit and finish are VERY good. Had to take off my front OEM mud flaps - PM me if anyone is interested in a set of lightly used from LX mud flaps. Will be dropping by West Marine to pick up some grip material so my wife's feet don't slide off unexpectedly when using.
full
Please ignore the color cast - grass color reflecting off body panels (4M9 Cashmere Beige). Only issue I had/have is can't figure out how to put in bolt on left/driver's side at the accumulator - without removing the accumulator that is. If anyone has a hint would much appreciate it. Meanwhile driving with it like many other AHC sliders, i.e., only two supports bolted up on the one side.
EDIT: Think I have someone interested in the mud flaps - thanks taco47001
full
Pm sent on those front flaps
Installed rear coil spacers on Gojira to account for the 1" lost with the (heavy) rear bumper, now back to the same lift it was with the stock bumper. Also gave it a bath.
Finally finished my $360 Front Runner Rack. Picked the rack up which originally was for a Jeep Unlimited for $300, spent another $60 on hardware and steel. Cut the width down to 50 and built the mounts. If I were to do it again I would change a few things, but overall I am pleased.
Jim
^ if it works, nice job!
Mind me asking where you sourced the spacer?
Where did you get the black storage box?
@bushdoctor - I bought it from BuyAutoTruckAccessories.com. I just checked though and they no longer carry it. Here's the description though since you can find it elsewhere on the web - Owens Garrison Series Diamond Tread Small ATV Utility Box - BLACK (32L x 6H x 12W).
Relocated the 7-pin trailer harness as after the Slee rear bumper, it was hanging down there by itself, begging to be sacrificed...
During the process I unplugged it from the harness and wired the license plate light for the relocated plate.
Took way longer than I would have guess, but it's really clean and I can still use my trailer harness with zero issue, so all's well...
Got a photo of where you relocated it that Slee? I need to do the same and want to see how you did it!
Thanks
Change out my front sway bar end links since the bushings on them were toast. Replaced the missing side cover on my roof rack. Replaced the fluid in my power steering reservoir with fresh ATF since it was a clear yellow/gold color and the pump was squeaking a bit at startup. I had also ordered new heater hose Ts which I planned to replace but after easily slipping the bottom hose off I found they must've been done with the last 90k service (about 3k miles before I purchased and 6k or so miles ago) so now I have a couple of spares.
