It bumps up the charging voltage by 0.5 volt across the board. Should help keep the AGM batteries happy.What is the purpose of this exactly?
Here is some more discussion about the various voltage boosters:
Are you going to keep the AHC or go conventional suspension? I bought mine used and vowed to keep AHC as long as it lasted but replace with traditional should anything significant go wrong. It got to 177k miles before AHC crapped out and I put in OME springs/torsion bars and Fox shocks. The AHC was a great feature but too tricky for me to deal with failures and mine has a good bit of rust so I figured more were soon to come.Finally figured out where my driver front AHC leak was coming from - thought it was the shock/hose connection until I replaced the seals twice and still had a leak. Can't complain too much since it's got 150k miles on it, but I'll have to replace the passenger soon as PM rather than wait for it to fail as well.
Hint - it's not supposed to be thinner in the middle there. Also, had to cut the top off with a grinder because that nut was not going to turn.
Just paint my 99 amazon green and updated front and rear to look like 06-07Took the family skiing in very very western MD, where it’s somehow 20 degrees colder than the DC area.
briefly parked next to a kindred spirit...gorgeous amazon green 200....
Replaced my alternator today in my LX. I don't know how people pull their alternators out of the bottom without draining the radiator and removing the lower radiator hose. It makes it 1000% easier.
So I need suspension. I figured this out the hard way. Beached it in a moment of stupidity, hate the air suspension currently.
I have been trying to resolve a pretty bad shake at 55 mph+ speeds. It is not so much a shimmy but a full on shake. Pumping fresh grease in drive shafts didn't help. Prying on U joints didn't reveal anything. CV axles are not leaking or seeping, they don't make any grinding or clicking or popping noise at any speeds.
So I ordered these parts from local Toyota dealership before even getting under the truck:
Drive Shaft
Front: 37140-60370 $259
Rear: 37110-6A610 $346
CV Axles: 43430-60040 $401
Total about $1500
Plan of action was to disconnect the front shaft and take off the front hub flanges to see if it would eliminate the shake. If it doesn't then remove the rear drive shaft would help.
But guess what? The driver side wheel has a large amount of play in it from the inner tie rod!! Like a really big, unsafe play when you grab the wheel at 3 and 9 o clock! and the steering rack boot is full of power steering fluid
So before anything else, I am planning to buy a tie rod kit from @cruiseroutfit and replace the tie rods to see if that addresses the shake. And then dump some AT 205 in the power steering reservoir to deal with the leak.
Or I could just replace the whole rack be done with it. Will need to get an alignment either way.
The CV axels 401$ is that the price for both or one side ?
NVM just did the math and it looks like you bought 2![]()
In the “what will I be doing to my 100 series this week” category, I present......
Thanks to @TRAIL TAILOR for the fresh bits to get my rear end in orderNow I have something to do with my free time while the spouse is away for a few days
There's never a bad time to freshen up your rear end! Post up your results when you get there, I think I might be chasing the same demons.
While the tie rod ends are on their way, I thought I would take the front drive shaft off to see if that would eliminate the drivetrain vibration. Welp, I failed like a miserable bitchI have been trying to resolve a pretty bad shake at 55 mph+ speeds. It is not so much a shimmy but a full on shake. Pumping fresh grease in drive shafts didn't help. Prying on U joints didn't reveal anything. CV axles are not leaking or seeping, they don't make any grinding or clicking or popping noise at any speeds.
Drive Shaft
Total about $1500
. I couldn't budge the front shaft bolts and while I could push it a little more, I got scared and decided I don't want to deal with that.
The other bolt was smashed at some point and has been mangled to a point that I can no longer get a socket on it. So the shield will stay on by that one mangled head bolt. Ended up draining the transfer case with shield in place, made a mess on the garage floor and refilled the case with fresh 75w-90 synthetic fluid.
