What do I have? 40 newb (16 Viewers)
Vintage TEQ @ToyotaMatt had some of the linkage components at his web store.
I've seen so many variations along the years, it's impossible to tell. A buddy of mine had a 72 FJ40 that used a cable, my 76 FJ40 uses a linkage.
Not really, its pretty cut and dried, if you take the po equations out of the math.
Co-signing @Chungas Revenge and adding... when I un-webed mine last year - was a mix of linkage parts from Mark @65swb45 and Matt @ToyotaMatt. Had no issues getting the parts quickly from them.
Mine does have a cable. Is stock linkage style? This would answer wether or not I can easily go back to stock, as I have no linkage and I’m sure it’s not easy to come By.
Also I’m not 100% the drivetrain/ engine is solid so I don’t want to jump off into a sniper setup yet.
everyone has an opinion...
Mine would be to put a knockoff carb on it with fresh mechanical pump.
- i use to get so many OEM Factory Land Cruiser Accelerator Linkage anything PM's every day my head would spin , it was a broken record skipping every few Swan Songs
- so , i decided to produce these T-TEN Tutorials via my Technical You tube Educational reference resource channel to self empower anyone knocking on my PM inbox looking for answers , forget the fresh gold plating , and all the NOS and reproduction parts involved here for a moment ....
- these set-ups 1973-12/74 F1.5 , 1/75-7/80 2F and the 8/80-9/87 FJ40 / FJ60 variants final revised refinement of nothing less then a Mechanical-Meshing Ballet of Precision JIS JDM Technology still to this day , is so dam fascinating to me , to watch it correctly installed , all the puzzle pieces , all in tip-top shape as MR-T intended . is nothing less the pure TEq BLISS .... 😀 🔊
- each TECH. video is in-depth in its own way shape and form , take the time and make the time to take this all in ,. because i did just that for people like you ...
- Safety is paramount here !
- so is replacing old tired wear-use parts ,
- JERRY-RIGGING these set-up is both un-safe & not tolerated in any way PERIOD !
- do it correctly , do it one time , and enjoy the results for the LONG-TERM , simple as that .....
FJ40 is first
FJ55 is second
- the
NEXT Links are Igram REELS , make sure you CLICK ON the volume and turn it all the way up , you will see , hear and feel what is indeed possible in this current day today all things Vintage TOYOTA Land Cruiser Accelerator Linkage ......:idea:
matt ...
FJ40 is first
FJ55 is second
- the
matt ...
So, what you're saying, is that I shouldn't have thrown away all of the linkage stuff when I decided to go to a Holley Sniper eh?
Sitting on the porch having my morning coffee today I decide to dive into the accelerator pedal stuff..
Mine 100% has a cable.
I looked at Toyota Matt’s website and I definitely don’t have the linkage that’s listed. The pedal is different.
What I do have is the same thing that’s listed on cruiser outfitters as 1968/69 only throttle cable.
Can anyone with a 68/69 post a picture of the carb linage that hooks this cable to the carb?
Thanks.
Also not much work to report being completed this week.
I did get it back inside last weekend and have spent about an hour on it throughout the week. I removed the doors to make life easier crawling around in the garage.
I’ve got the wiring harness 75% out of the dash. It’s all loose and ran in from outside the firewall, I just need to snake it out from behind the vent linkage. Or get the vent cover off so I can remove the vent linkage and just take the wiring out. Not much free time to spend on it. Baby steps however.
Looking at Matt’s website this morning. I could burn a few paychecks pretty easily there.
Full disclosure - I'm new to all this as well (and reserve the right to be naïve) and removed the Weber and went back to Aisan. I looked up 1969 schematic - I think I did - look here at the various accelerator options from 3/1969-1975 (as I understand it). Might help see where you are. Webers are via cable and the PO butchered the gas pedal on mine enough that I could not go to linkage w/o getting an unmolested pedal - I got one cheap inexpensive.
What year carb are you going to? a 1969 - then the cable would work. A 1977, you would need to look at the linkage option, again as I understand. Decide/know the carb you are going to it so you spend only as many paychecks as you need. I will say from my experience, even though this has been a PITA, I am glad I went down this road of removing the Weber.
My opinion, and maybe worth what it costs, nothing.
Cheers
Cheers
Thank you, I’ll read through there.
Here’s what I’m working with. If I go back to stock carb I’ll do my best to get a 69 exact fit.
Ignore the rats nest of fuse box.. that’s in my Toyota Matt shopping cart.
Thanks.
so u have this set up going on ?
1552250638721-png.1924015
That appears to be the most accurate representation of what I have.
Keep in mind I have the cable still on the body but currently have a Weber 38.
i think its time for you to POST photos of ALL 6 sides of the set up you have going on ?
sound like a plan right !
do this here in this tech thread and report back
thanks ,
- not sure why i just noticed the word WEBBER , but those carburetors are the LIVING example of GHETTO gone bad
thanks ,
I posted the linkage at the carb and pedal above..
Unless pics aren’t showing up?
Is that a Weber carb? @red66toy just posted what I think is a period correct Toyota carb if your going to stick with stock.
Yes that is a Weber--would recommend returning to the orig Aisin(sp?) carb-- get rid of the OEM exhaust mani and get a set of headers(look that up on the forum for the new header manufacturing thread(a Downey return from the grave by some serious Mud members--never to be duplicated)--they need the support of all of us--order now--you will never-ever be disappointed in he product or the performance)
DITTO ^^^_ I pretty sure I picked up one of the last Downey/Marks headers years ago and swapped out an old Rochester Carb in the process. JimC rebuilt an original 76 carb and I sourced the correct linkage from MUD Members in the Want adds.
@gonzopancho is your go to for the “new” reborn header. Call Mark at “Marks Off Road” @65swb45 for your carb and linkage needs.
Two of the best “upgrades” I ever added.
Toss in a new starter (Gear Reduction) and a new Dizzy (I went Electronic) and you will be in the “High Cotton”….🍺
It’s got a header (although not sure make or how solid it is), electronic distributor, and gear reduction starter already on it.
I’m still searching the web for pictures of a 68-69 carb setup
