- Joined
- Aug 12, 2007
- Threads
- 963
- Messages
- 19,507
Vintage TEQ @ToyotaMatt had some of the linkage components at his web store.
I've seen so many variations along the years, it's impossible to tell. A buddy of mine had a 72 FJ40 that used a cable, my 76 FJ40 uses a linkage.
Not really, its pretty cut and dried, if you take the po equations out of the math.
Co-signing @Chungas Revenge and adding... when I un-webed mine last year - was a mix of linkage parts from Mark @65swb45 and Matt @ToyotaMatt. Had no issues getting the parts quickly from them.
Mine does have a cable. Is stock linkage style? This would answer wether or not I can easily go back to stock, as I have no linkage and I’m sure it’s not easy to come By.
Also I’m not 100% the drivetrain/ engine is solid so I don’t want to jump off into a sniper setup yet.
everyone has an opinion...
Mine would be to put a knockoff carb on it with fresh mechanical pump.
- i use to get so many OEM Factory Land Cruiser Accelerator Linkage anything PM's every day my head would spin , it was a broken record skipping every few Swan Songs
- so , i decided to produce these T-TEN Tutorials via my Technical You tube Educational reference resource channel to self empower anyone knocking on my PM inbox looking for answers , forget the fresh gold plating , and all the NOS and reproduction parts involved here for a moment ....
- these set-ups 1973-12/74 F1.5 , 1/75-7/80 2F and the 8/80-9/87 FJ40 / FJ60 variants final revised refinement of nothing less then a Mechanical-Meshing Ballet of Precision JIS JDM Technology still to this day , is so dam fascinating to me , to watch it correctly installed , all the puzzle pieces , all in tip-top shape as MR-T intended . is nothing less the pure TEq BLISS ....
- each TECH. video is in-depth in its own way shape and form , take the time and make the time to take this all in ,. because i did just that for people like you ...
- Safety is paramount here !
- so is replacing old tired wear-use parts ,
- JERRY-RIGGING these set-up is both un-safe & not tolerated in any way PERIOD !
- do it correctly , do it one time , and enjoy the results for the LONG-TERM , simple as that .....
- FJ40 is first
- FJ55 is second
- the NEXT Links are Igram REELS , make sure you CLICK ON the volume and turn it all the way up , you will see , hear and feel what is indeed possible in this current day today all things Vintage TOYOTA Land Cruiser Accelerator Linkage ......
matt ...
