What Did You Do with Your 80 This Weekend? (46 Viewers)
Removed old busted power steering cooler (18 years of rust made it way more difficult than it should have been). Then installed new mo' betta power steering cooler and new low pressure lines. My high pressure lines are already fairly new. I had to cut the old system out in pieces.
JJGarcia and I pieced the 4x4 Labs bumper together and mounted it. Still some primer and paint to put on the bumper but a great days work. Thanks JJG!
Zona
Oh, also moved my passenger seat back manually since it's all geeked up. I pulled it part and all the gears look ok, that little white plug is just stripped out again already. I don't know what's going on with it. I'm thinking the two rails that it moves on are out of whack and causing the plug to strip every time it gets moved.
Cleaned out all the crud and mud
Filled it will fuel
Washed the windows (inside, raining today in Seattle)
Looks good @Teddy I would wrap a sheathing of some sorts around those lines where they pass through the crossmember, and anywhere else they are in contact with surrounding. Edges/surfaces
Zona
Looking good!:cool:
Nice except I don't make anything. Those two deserve the credit.
You did tons of research, shared it with all of us and sure as hell deserve credit for that:cheers:
Jumped the gun on Elocker swap.... Forgot the two long studs required... Meeow. :(
So I did the tweeters instead. 2 @ Apillars and 2 @ 'attic rack'. Seriously helps w the factory locations(at everyone's knees).
Built a cover for the subwoofer box, since everything seemingly wants to get near the speakers and bounce on them.
Took the :princess: to get a coffee, then we decided we didn't want to go home so we headed north to scout a few campsites and let the pups run. It was great to get some gravel under the tires.
Yeah, I'm going to get to that today hopefully. I was tired when I finished yesterday and realized that I forgot to pick some up at the store. Long story short, I drank beer instead.
