What Did You Do with Your 80 This Weekend? (47 Viewers)
Took the 80 on a week-long jaunt. Started out in Florida and made my way up to Pisgah National Forest in North Carolina. The first night I camped along the Blue Ridge Parkway. Probably drove a tad too fast on those windy roads but that's no RTT on 33's privilege.
Found a cool rock wall on some random forest road. A good place to stop and pee too.
Eventually made my way to the South end of the Smokies and drove 441 right up through the center. Way too many people doing the same thing of course. Had absolutely no plans or camping reservations after that so started driving West and googling. Stumbled upon some remote National Park campground that was lovely. At that point, I was starving and too lazy to cook so I drove 30 mins back to town to get some arroz con pollo to sit by the creek in my hammock because what the hell. Probably my favorite night of the trip.
Afterward, drove to Oliver Springs, TN to attend GSMTR. Didn't feel like beating my truck up on the trails so went and explored a local state park the first day and rode a black diamond trail the next with a friend. Had a blast on that and decided I'm eventually building a beater truck that I won't mind denting all over. Overall a great time, right at 1,700 miles round trip, the 80 didn't skip a beat blasting down the highway at 85 coming home, and of course didn't win anything at the raffle.
Looks like a great trip, mind sharing the Co-ords or address or something for the state park campground? Looks like an awesome spot
Awesome pics. I am calling BS on an 80 hitting 85 mph and not being scared for your life :)
Spent the last week doing cleaning up and post trip maintenance. Wheeled at windrock most of last week attending GSMTR2023.
Pressure washed for 2 hours to get all the mud off the undercarriage. Changed the oil and filter and changed the trans fluid.
Still waiting on the new throttle cable assembly from Toyota and the truck is ready for the next trip.
Still waiting on the new throttle cable assembly from Toyota and the truck is ready for the next trip. View attachment 3356660
I am heading down to Knoxville from Ohio next month on vacation. A buddy of mine lives 20 mins from WR. Excited to check it out. Probably head to Royal Blue as well.
Not for myself, but for a local FB group member's 80 series. Used my own rig for mock up reasons.
Made an amp/crossover mount utilizing the 3rd row seating.
Started with the "skeleton" which acts as the initial mounting platform for both the mounts and MDF. Cut on the CNC plasma table making this a 5 minute job from drawing to cutting.
Cut and bent the necessary mounting brackets to utilize the pre-existing mounting points. Press brake making easy work of 1/8" steel.
Just mocking up how it'll sit; level with the window with enough room behind as the openings serve as space for each of the 4 crossovers. This will keep all the wires hidden behind the setup.
Bending 1/2" rod sucks, but enough heat makes it doable on a vice. Not pictures of that but here it is tacked up.
Final product welded up.
I'm not doing the stereo install, just the making of this mount.
He'll need three more (for the other side and for his other Land Cruiser) so it'll just go that much quicker next time.
If I get pics of his install, I'll post them up here.
Decided to troubleshoot my inoperable rear locker. Read all the threads on troubleshooting, then climbed under with tools and testing things. Motor is bound, and the 2 top bolt heads are stripped holding it to the 3rd... just cammed out. Gave up for now, and letting them soak in penetrating lube. Not sure if those extractor sockets are too long and will hit the motor or perhaps extractor wrenches will work. Someone has been in here before from the looks of things.
Try a Snap On flank drive plus wrench. I bet it will remove those bolts.
So, I looked into the Snap-On, MAC, Capri, and HF versions of extractor wrenches. That day (Monday June 19) ended up ordering 1 MAC 10mm and a set of the Capri's. The Capri's were an Amazon 1 day delivery, the Mac arrived today (Sat June 24) . Tried both wrenches... MAC, no dice. The Capri's wave box end were the winner here because I could get just enough swing/angle to avoid the upper control arm. Still required a bit of maneuvering and jacking up the body and unbolting the line/bracket attached to the upper control arm helped. Once the wrench had a bite - some inward pressure and a rap with a hammer cracked them loose.
Locker came off fine, opened up the locker cover, pretty clean, opened up the motor - magnets came loose, but other than that pretty clean. So, off to clean that up, glue the magnets, RTV, and dig up some new bolts and get it sorted. Also ordered a CDL switch which arrived today, so feelin' good!
Headed out to Hidden Falls with my wife and my son. I was all set to share video shot with my GoPro but I lost it somewhere on Slither or Bronco Buster. Damn it! I had attached it to my ARB front bumper with the suction cup mount. I’ve used that mount to secure it to motorcycles I road waaayyyy over 100mph. Oh well. Live and learn.
It was my first time taking the truck out since it’s been triple locked. I could not be more pleased with the way the Eaton E-Lockers performed. It also my first chance to put my WKOF skid plate and sliders to good use. I used them to pivot on a couple of obstacles. Again, they worked great.
Tested out the kayak mount, bike mount, loaded 100's of pounds of unnecessary crap and headed to the hills.
Only slightly disappointing part is the Dobinson MMR shocks and tapered coils. Clearly made for a very light setup.
Treated her to a full new exhaust system from the manifolds back and all new upgraded rear control arms.
Previous owner did a few wacky things with the exhaust. Those things finally failed and I’m pretty sure the original muffler from ‘97 was still on it. I’ll eventually make my own exhaust from the cat back, but in the meantime this the finest rock auto exhaust money can buy. Lol
View attachment 3357415View attachment 3357416
Your second cat is in backwards. They should both be in the same plane.
Nope, this is how they go! The flanges are welded on in this manner.
