Leaking out of the reservoir where the top and bottom pieces are pressed together?
Original reservoir?Maybe. I need to clean it good and check. I can't seem to see it leak at idle moving the wheel(someone else moving wheel)
Original reservoir?
Screen in the bottom may be partially plugged causing slight pressurization and it’s leaking at the seam.
I took mine apart and the contamination in there was crazy. Pulled screen out and sonic cleaned it. I was surprised fluid was actually passing through the screen at a reasonable rate so it could keep up with the pump!
Builds - 1993 80, BUILD, another "it has begun" for fjbj40!
Pulled the down pipes as I want to move the O2 sensors to the manifolds in the PAIR position. Luckily the bolts on the cat were new and came of without effort:clap:. Having luck again one O2 sensor looks pretty much new, the other looks original and so did the nuts! I broke out the carbide burr...forum.ih8mud.com
Post#31
Dang Sam show us your 80!Doubled its value
Oh that’s right Your a Chevota guy!Dang Sam show us your 80!![]()
I will be! But am not yet.Oh that’s right Your a Chevota guy!![]()
Haven't had time to do much except drive it. But ask and you shall receiveDang Sam show us your 80!![]()
Original reservoir?
Post#31
I spent $45 on a new one two years ago and have yet to install it.Mine was dirty but not that dirty.
However I feel that between a few tabs being less than tight and the seal being hard as a rock, that was my leak.
Cleaned. Fipg on the seal. I'll let it sit over night and test it tomorrow
View attachment 3205418View attachment 3205419View attachment 3205420View attachment 3205421
Because mines a DD and I need to make the time for the effort.
I need to do a radiator, alternator, and oil change so this is the time I need to do that too!
