What Did You Do with Your 80 This Weekend? (42 Viewers)
Intake and fuel rail on when I drop it in. It’s easier.
Last one I did was on a engine stand so I had the whole motor assembled. Wasn’t sure if I could have the whole intake installed and fuel rail. That will Make life much easier thanks!!!
Found someone to straighten things out enough to get a window in, now I need a few trim bits.
Man all these new engines and heads gaskets ... I changed my engine and diff oil.
Why settle for just changing the oil. Get a new motor instead 😂
Took mine wheeling and shot some grouse!
Finished up the Trigger 4 install. Lights should be here next week.
Replaced fan clutch with Aisin blue hub unit from Amazon.
I saw on amazon several Aisin fan clutches suitable for LC80 (FCT-xxx).
Do you mind sharing which one you've installed and why?
Today… I found the true purpose of this holder in the center console. Bravo Toyota… you never cease to impress!
This past Father’s Day my daughter found a better way to use that space after she couldn’t find a way to charge her phone and power a computer while in my 80. Adapts to my Milwuakee M18 battery.
Had smoke coming out of left wheel, after some fidgeting seems I lost bearing grease. Brakes are OK I guess seems like ball bearings are running hot there is a slight grind when I turn the wheel by hand
A little fabricobbling this morning.
My roof rack light basket developed a crack that needs repair and I threw together a couple little brackets for the old man's side by side.
TRAIL TAILOR 4340 Chromoly Full Float Rear Axles are now available.
On sale for opening release.
Jason
TT
Put on a set of the Magnaflow direct fit cats....no more rattles and whistles...Certainly not the cheapest option out there, but i like the more compact size over the OEM version. Also waiting on some White Knuckle sliders, so made sure the threads in the frame were nice and clean...
