What Did You Do with Your 80 This Weekend? (56 Viewers)
Tip came off yes, they are going to remove the exposed bone and let it heal over
It's only a flesh wound...... it will heal up fine. I bet you will have a little permanent numbness on the tip. Mine always feels like I have something stuck under the half fingernail that grew back....
Goodluck man
Snow and ice here. Tucked away for the winter. I keep mine too nice to expose to Land Cruiser Kryptonite ROAD SALT!!!
Somebody asked what a new 1fzfe sounds like. Well, there you go.
Specs:
-new short block, cams, head, valves
-new ignition system including coil and igniter
-all new sensors throughout
-new crank pulley-harmonic balancer
-Otramm cat back with new OEM y-pipe and forward cat
-injectors rebuilt and calibrated
-Timing set to 8* after break in period
-2400 miles on engine now
Revs extremely smooth through the power band. Slight drone with cat back and no resonator.
Cheers
I'm doing something very similar with my exhaust. Do you have a source/ part number for the y-pipe clamp?
90461-32031?​
first post on mud but I’ve been stalking for a long time but I Added a snorkel and a set of rigid lights to the bumper till my ARB bumper comes in (hopefully by end of the week)
Changed the fluid on the transmission, transfer case and rear end, at some point the transfer case was filled with transmission fluid filled it back with 75-90 and the rear end fluid looked it was never changed in the 129k Miles of its life
Who carries the new brush kit? Mine is likely getting tired, never been replaced at 225k
I just ordered one from eBay for $24. My alternator still charges fine for having 330k miles but I’m sure it will be happy with a new brush assembly. Brand New Genuine OEM Toyota Scion Alternator Brush Holder Assy 27370-75060 | eBay - https://www.ebay.com/itm/Brand-New-Genuine-OEM-Toyota-Scion-Alternator-Brush-Holder-Assy-27370-75060-/223520815923?_trksid=p2349624.m46890.l49292
Finished patching the quarters on both sides that had rusted out. It's not perfect but it'll be behind the bumper so whatevs. Main thing is I cut all the old rusted crap out. Driver's side was even worse. Next up is repainting an upper lift gate I got from @slow95z along with a new window seal.
So far I'm seeing a big improvement over the Hella's, which surprised me since the Hella's were actually a really good light for the price. Distance is MUCH better with these. I got the 9" version of these lights. There's a bit more detail in the post I made in my build thread. Honestly, the only difference I'm aware of with the 8.5" and the 9" versions is that the 9" version that I have has daytime running lights (rectangle shaped lights around the outer edge of the light). Since the 80 doesn't use DRL, the 8.5" ones would work essentially the same.
you got a link for those hella .?
Added a fold down table to my swing out carrier. Going to be adding a few other things to it in the near future.
