COYS
Very nice tire and rim setup, perfect setup, could you share wheel spec and tire brand? Thx
-38mm, bfg ko2
You've got one of the best 80's globally, I've followed your build thread, watched you wheel on YouTube (Rubicon, etc.). I say this not to sound like a wise guy; but, the air foil thing on the back of your rig is gone? I have found it to be extremely functional by pushing snow, dust and rain away from the rear hatch window. Just curious on why you removed it?Skies were muggy with all the recent fires in the area but it was still a great weekend away from the valley heat
Our 80 supported our Jeep... to pick up a few parts and tools.
Spent 4 days pulling/reinstalling the gearbox/xfer case out of our jeep to replace a leaking slave cylinder. Having only worked on patrols/cruisers/landrovers I had never seen an internal slave cylinder (what a deranged concept). At least a new pressure plate/clutch plate (may as well replace if pulling the boxes) and thrust/slave combo was only $150 delivered.
Younger son (summer holidays back from college) pitched in to help and learned a lot of tricks on how to do such a job. We built an adapter (have plasma cutter and welder) to sit on our floor jack to support the entire transmission. Made life a lot easier when we had to align and mesh the box back onto the flywheel pressure plate/clutch assembly.
I was boggled to see how tiny the fasteners are that hold the saddles over the prop shafts ujoints. M5 size (8mm head)- really??!? The other brilliant piece of engineering design is the mix of 10/11/12/13/14/15mm size bolts and of course Jeep has to throw in some star heads (female torx) just for fun. e.g. the starter motor has 2 sized bolt heads to retain it. Dear god, madness... Glad our Jeep is basically a city vehicle, can't begin to imagine it out bush and needing some repair - would need a snap-on truck in tow
Bell housing cleaned up so we could see and remove the thrust/slave combo on the gearbox shaft. Cleaned up the rest before reinstalling so not having to deal with decades of oil/grease residue.
cheers,
george.
That, and something seems missing in the interior. Hmmm.
Easier to clean this way
Which sound deadening did you go with? Any good for temps too?got at the sound dampening with the wife..... waiting for the foam to arrive today so I can get the back end together, stoked that my Wits End quarter panel just arrived as well !
A beer?
That is fatmat...at least on the bottom. The sides is rattletrap
View attachment 1757642 View attachment 1757643 View attachment 1757644 View attachment 1757642 View attachment 1757643 View attachment 1757644 View attachment 1757645 View attachment 1757646
Zona
Does one hold better on vertical surfaces than the other?
I double the floorpan - 80 mil and 50 mil on top..... will be putting a 315mm foam layer across everything that's flat as the final touch... I'm not quite as OCD as @Boltripper but aspire to it after reading thru his thread ! I will be doing the headliner area as well with dampner and foam but waiting until my shop can recover it while it's down.... I will say the rattletrap is stickier so likely will use just that and foam.Does one hold better on vertical surfaces than the other?
