For the record, I wash the undercarriage 2-3 times per week during the winter. Not just weekly. Weekly isn't obsessive enough.
Once a week on winter it's pretty standard.
Wait... You flush your brakes annually? Is this a real thing, or like @LS1FJ40 's obsession with washing his undercarriage weekly?
"It's my undercarriage, I'll wash it as much as I want! "
I hope this is techy enough. I'm not a wrencher but I love this site and don't want to be a rulebreaker. Found a use for the old car phone mount I haven't removed. Apparently some metal under there. Good for opening IPA's when I'm parked for the night.View attachment 1244225
I also flush annually along with carrying Dot 4 and a bleeder hose on board. After the first time you boil your old fluid and loose your brakes coming down switch backs you will start doing it also. Brake fluid takes on moisture as time goes on making boiling more likely.
Are you serious? I'm a newb, so help me out.Take note your Land Cruiser comes from the factory with seven bottle openers installed.
Brake fluid is cheap. No reason not to carry it.
Nice! Damn good beer too.Here's one...
One of the first things I did when I bought mine. I flushed about two big bottles of fluid through the system. And I'm not one of those "baselining" types at all. Brakes worked MUCH better afterwards.This is good! I didn't know annually was a good maintenance interval for this. I thought you only did it when it started looking nasty. I do carry brake fluid, I'll just start refreshing it more often. This is a great thread! I learn so much tech from all these weekend comments!
I have left my 63 qt ARB on in my truck for 30+ hours. The truck was slow starting, but it did start.Thanks for the info!
That is actually how I did it.But most of the fluid in the calipers themselves stays dirty, correct?
Perhaps do the turkey baster method for a few days then crack the bleeders and let the new stuff displace what was in the calipers?
I do the "dirty" method. Turkey baster or syringe and suck out the brake fluid from the master cylinder then add fresh. Drive for a day. Repeat. After 3-4 it looks pretty damn good. I'm doing mine on a 6 month interval. It takes about 3 minutes and easy to do by yourself.
I learned this method on here. I'm sure the purists don't approve but it is a hell of a lot easier and means my fluid actually gets changed.
I was going to get one from HF, but the 2.5 star average scared me off. Looks like it's either 5 stars, or 1 star for it, very weird. Is this the one you're talking about?Actually spending ~$20 at Harbor Freight and purchase a vacuum bleeder. Use the turkey baster to start off with a clean reservoir then vacuum each wheel. Not only will you end up with fresh fluid through out the system your brakes will work great.
I sucked all of it out of the master... I noticed it get visibly darker each time ...Hmmm.
