Removed all the broken wood trim from the 80 by following a thread here from 2008.
If I was to have my A/C system evacuated, what else would one do while they were in there?
I found a good guide on the condenser box.
A/C system - how to remove the cooling unit, evaporator, expansion valve
It's summer and some of us are experiencing A/C troubles so I think it's time to do a writeup on how to remove the cooling unit, evaporator and expansion valve out of a '97 80 series. Removal of the cooling unit is very straight forward, plan on about half hour and minimal cursing :D You...forum.ih8mud.com
anything else?
Decided to change the front diff oil since I have had the truck for almost a year, and it hasn't been checked since the pre-purchase inspection. Couldn't budge the drain plug, so will be borrowing an impact wrench next weekend. But glad I checked the fluid, as it seemed almost empty. Ended up putting in 1.75 qts. Will drain and fill again next weekend, along with the rear.
As recommended by Mudders, ordered the Allen wrench replacement plugs, from Wit's End. While under the truck, I noticed that the sway bar bushings were cracked and split, so ordered those while I was at it.
Oh yeah, and I also designed a sticker! Thinking about throwing them on Etsy. Thoughts? Special deal for Mudders, of course! Coming to vender thread soon!
Bearing in the compressor rotor is toast, it wobbles (weaves?) and is quite loud when driving, and clunky / noisy when turned by hand (Idler was replaced by PO, is quiet when spun)To answer your question, you need to let us know if you have an A/C problem, and we should clarify some terms. Evacuating the system is not removal of the refrigerant--that is called recovery. The box behind the dash contains the evaporator, and the condenser is in front of the radiator.
Is there a problem with the A/C system?
Bearing in the compressor wheel is toast, it wobbles (weaves?) and is quite loud when driving, and clunky / noisy when turned by hand (Idler was replaced by PO, is quiet when spun)
I have the belt off now, but want to get things sorted out before the heat arrives in NC
My next steps are:
1. Try and loosen the compressor while keeping the system charged so I can get a better angle on the snap ring that holds the compressor wheel on.
2. If that works then replace the bearing.
3. If I cannot get to that snapring, I will probably recover the refrigerant, pull the compressor, clean out the condenser box, evaluate fixing the compressor wheel, or just getting a whole new compressor assembly (denso direct replacement is $200) (which includes a new compressor wheel and bearing)
IKR?! I was using a six point socket and breaker bar, but my bar is only 15". I will see if I can get my hands on a longer one (TWSS!) And try again.I never understand why those drain plugs cause such trouble, when the torque spec is only 36 ft. lb. Using an impact wrench may also not be the best idea--a quality 6-point socket and a breaker bar should do the trick.
I have not yet, no. But I've been thinking about joining. Is there a February meeting? The website mentions March at a new location, but nothing about a February dateInterested and I am right here in DFW. Do you attend the LSLC meetings in Allen?
Does he have a website to order from?
Nice work. ARB, because they are not intended to be recovery points...Finally got the jerry can holder from 4x4Labs fabbed up so I bolted it on today. Added a mount for a propane tank underneath.
Also beefed up the recovery points on the ARB front bumper. I’ll never understand why they made them so thin. I’ve seen several that were bent from an off-angle recovery.
Fair enough. Just saw the other post about their being intended for a highlift jack. They should be suitable for recovery now that they’re an inch thick….Nice work. ARB, because they are not intended to be recovery points...
Like @Comet stated, HiLift acc attachement is used there..Fair enough. Just saw the other post about their being intended for a highlift jack. They should be suitable for recovery now that they’re an inch thick….
