Those ambers look mighty nice in thereFinished up my Coastal Offroad bumper.
Got lucky and happened to be in Blue Ridge, GA for some light snow action.
Did a little boating.
I know what you are thinking…
“Big deal, your locker dial works. Woo. Hoo.”
And you would be correct. Except it’s not with Toyota e-lockers nor ARB air lockers. It’s with Eaton (Or Harrop) magnetic clutch lockers using the factory dial. So much satisfaction.
The biggest hurdle is just converting the Eaton’s positive switching to Toyota’s ground switching to keep things consistent so you can use the dial.
More info to come including a potential “mostly” plug-in harness.
FWIW the Eaton harness is an improvement over the Harrop ones from 5+ years ago.
Yup...The ARB tabs are intended to be used with the ARB highlift adapter. As stated above, they are 100% NOT recovery points. Attempt to use them as such and you may be recovering in hospital (or feeding the worms).
And what I added is also reinforced in the back with a large plate to spread the load - don't want the nuts ripping through the relatively thin ARB steel in that area.
cheers,
george.
That shoe for an ashtray though lol3 day snow storm offroad trip to Israeli Syrian border
We decided to go just when it started to snow, knowing that Israeli police will close the roads before the snow and the ice and spend the night at the USSR bullied Syrian army headquarters that was taken in the 1967 war.
a small fire pit and a warm tent with my espresso maker is all needed
Surprised me too - The LC is about the same size as my GX460.I parked next to an fj today. I parked next to a new 4runner the other day.
I always thought land cruisers were big. But compared to modern offerings the 80 isn't that big.
View attachment 2910923View attachment 2910924
Funny that this would come up twice in a few days. I’ve seen them bent up from people using them as recovery points and they always looked dangerously weak to me. I couldn’t believe that they would design them so poorly. That’s why I had the 1” reinforcements welded onto mine. I’ve also seen people use the shipping tie-down points as recovery points - also scary.The ARB tabs are intended to be used with the ARB highlift adapter. As stated above, they are 100% NOT recovery points. Attempt to use them as such and you may be recovering in hospital (or feeding the worms).
cheers,
george.
Interior space is much more usable too due to the drastically different safety regulations of the time. The 80 is about as close to perfect size as you'll find imo.Surprised me too - The LC is about the same size as my GX460.
Yup ... That and the fact you can't remove the 3rd row from the GX460, which seems like a massive oversight for those of us who don't have to take a gaggle of kids to soccer practice.Interior space is much more usable too due to the drastically different safety regulations of the time. The 80 is about as close to perfect size as you'll find imo.
If you mean the negative switching for the dash lamps, transistor switches are simple enough.The biggest hurdle is just converting the Eaton’s positive switching to Toyota’s ground switching to keep things consistent so you can use the dial.
cheers,
george.
Strangely enough my speakers all stopped working this weekend after installing a light bar and rocker switch...so I'll be diving into stereo stuff this weekend. My lack of quality sounding tunes while LandCruising is something I've been putting off for far too long.Put a stereo in it. Between the land cruiser and my 66 I've been driving with a blue tooth speaker on the dash for almost 3 months. I forgot how nice a stereo is.
If you look back a couple of pages I posted a pic of mine. I had 1” steel plate welded onto mine to beef it up.Thanks.
What about adding 2 reinforcement plates on each side of the lifting point and welding them altogether?
It's best if you run a solid peice through the ARB and tie it to the frame at the bolt points. Finish by welding on both front and back of the ARB face. @NLXTACY did this year's back and a great example...Thanks.
