What did you do with your 60 this weekend? (11 Viewers)
Ticking off small projects while I wait for parts that are keeping this thing from being a driver again. I remounted my shocks in the correct orientation ( for some reason I mounted them as if they were struts with the shaft at the top)
I also did a little craigslist rebuilding on the sway bar bits, air box and steering stabilizer mount.
I'm waiting on a longer front frame to axle brake line, sway bar end links and bushings from Toyota and a master cylinder gasket.
Things needing to be done
  1. Install 80 MC once I get the gasket
  2. Install longer front brake line and mount the T fitting to the axle
  3. Weld in panhard brace bar and bracket
  4. Mount frame side stabilizer bracket
  5. Sway bar end links mounts
  6. Compare and set toe in relation to my 80 series that drives great.
  7. Bleed brakes
  8. Wheels on and enjoy that sweet sweet coil life
  • Back
