What did you do with your 60 this weekend? (28 Viewers)
Long weekend in the shop.
✔️Clutch master and slave replaced
✔️New OEM body mounts on the front corners
✔️New radiator installed
The clutch master & slave should have been easy, but the flare nut at the end of the hard line was over tightened to the drop down hose, and it trashed the internal threads of the hose coming out. @RDub suggested I make a thread chaser out of an old brake line I had around, so I did. That’s a good one for the trick bag. Worked like a charm and made the project a success.
The front corner body mounts on my truck are much worse than the rest - chunks of rubber were falling out. Replaced with OEM. I wanted rubber rather than poly to maybe have a softer ride and less rattles, even if they won’t last as long.
Original radiator put in 42 years of work and was leaking badly so I picked up a gently used CSF from @Rockymtnreaper with the intention of getting by until I get the original repaired. Got it in, forgot to move the fan shroud out of the way and it was pinched between the diagonal frame gusset and the lower rad tube inlet. Had to take it all apart and readjust. At this point I’ve been going all day, it’s 11PM, so I fill the thing up and start driving home. About 1.5 miles down the road my temps are creeping up fast. Takes me 1/4 mile to pull over and shut it down, and at that point my temp sensor in the upper rad hose is showing 240*F and the coolant is boiling. Oops - I forgot that when I filled it when the thermostat was as closed, so I was only partially filling the system. Waited for temps to come down to about 170, cracked the cap, and filled it. It took in another 1.25g and was cool all the way home - arrived at 12:45AM this morning.
Questions: how much damage could I have done with the short overheat condition? Also, these radiator brackets shown below are directional, but I forgot which way they were when I took it apart. Anybody know how they go? The difference is that it can move the whole radiator about 1cm closer or further from the front sheet metal.
Thumb points forward
I’m going to say don’t really worry about the short overheat. I overheated my 3FE one night because the water pump sized and blew up the top of the radiator, put a new CSF radiator and Aisin water pump in and everything was fine, still running both. Replaced the head last year and didn’t see any cracks or failures in the head or head gasket.
Where did you order the mounts from?
They were original to the truck. My wife spent some time on them with a wire wheel while I worked on other stuff.
Was at the coast for work and found this guy in the parking lot...
Then had to do obligatory drive out on to the beach. There are only a couple of spots here where we can drive so anytime I am out this way have to make at least one pass.
Awesome. I like the gauge selection, haven’t seen that speedo before
These are the dual and quad combo gauges. Their new LED models.
HOWEVER, they did away with a dimmer switch/dial and made "settings" for night brightness. So the driver has to program the night brightness they prefer. SUCKS, IMO for a multi-driver vehicle....
Just my .02
Installed the Morimoto 2-stroke 4.0 in the H4 Koito headlight upgrade I did a few years back. I'll get back to you all when I try them out.
It's a win! Great cut-off on dims, no excessive sign glare or weird patterns. Like stock but much brighter without being a nuisance. If you have the H4 Koito's you will like it.
Any chance you could post up some pics of the light's performance?
