Doesn’t the Tundra Brakes/4Runner Hubs mod require 17” wheels?
I think with older Tundra calipers a 16" will work.
I will suggest fixing and not sellingToday, I pulled the old gal (1986 FJ60) out of winter storage (since spring has finally arrived here) and she started right up after a couple of ounces of gas were poured down the carburetor - both the choke cable and the throttle cable seemed to have seized over the winter storage months - I couldn't pull out the choke cable, nor could I press the throttle. Regardless, after a couple minutes of rough idling, the 2F settled in at about 750RPM all the while I washed her up.
So, do I replace the two cables, or do I try and grease/regrease them so they function?
Or do I try to sell her as is?
Looking for advice. Thanks.
Went and played with a 93 FZJ80 series this weekend again!
Chandler AZ.
View attachment 1971224View attachment 1971225View attachment 1971226
what horn did you upgrade to?Finally finished buttoning up my 62 after a marathon of maintenance and improvements. Replaced my busted fuel gauge with a good one from @orangefj45, installed LED headlights (have yet to see if I'll like them in my H4 housings or not. It's just LED bulbs), upgraded my horn, replaced my radiator, installed an auxiliary tranny cooler, and replaced the transmission cooling lines with -6AN hose and fittings. Refilled the transmission with Schaeffer's ATF too and WOW what a difference. Shifting is smooth like butter, truck drives much smoother overall, and with the cooler it takes a good long time to heat up. in 44 degree weather this morning on the highway it took nearly the whole commute to get up to 140 degrees, then didn't climb above 160 during the long uphill drag in 3rd gear towards the end of my commute. Very curious to see how it does going over the mountain passes.
And the horns are LOUD, and a great tone for a 60 series. I passed a friend on the freeway on my way home and honked at him, and he about shot up through the roof of his car
Yes we did that. Main reason I went over there was that pesky oil leak from the oil pump coverr. Did the front seal as well.Do the oil pump cover and front seal while you're in there!
Georg @ valley Hybrids & Cruiser Brothers
I went with two sets of WOLO Sonic Blast horns. Each comes with a high tone and low tone. Most cars typically just have one of each, but I got two and made brackets to mount the horns to that attach to the AC condenser mounting bolts. Got longer bolts with 3/8" long spacer sleeves to stand off the horn brackets from the condenser and wired all four horns in parallel powered by a 30A relay. I had 12ga wire that I used, but you'll get plenty of current to them if you use 14ga wire. I just used my 12ga silicon insulated wire so it would stand up to the heat from the condenser and tranny cooler without having the insulation get brittle over time.what horn did you upgrade to?
sweet! nice work! I've got plans for something similar in the future, but my drawers need to be deep, nearly the 6' depth of the area behind the front seats. Way to go!
