You gonna throw those Kubota tires and wheels on there tooThis is in the works. Thanks to @nvrlose54 Shaw Fab for prepping the axle housing.
View attachment 1967349View attachment 1967350View attachment 1967351
@GodwinThose spring perches do not look right, I would cut those off and re-do. That steel looks too thin and I would be concerned about it being crushed when the U-bolts are torqued or over time.
hey does that mean we'll get to see you at the CSC meetings in Tempe with this awesome truck?Loaded up some house crap and took it to our new place in Phoenix. One less thing to worry about when we move completely this weekend.
Possibly! When is it?hey does that mean we'll get to see you at the CSC meetings in Tempe with this awesome truck?
The perches are the same thickness as factory. Plenty strong.Those spring perches do not look right, I would cut those off and re-do. That steel looks too thin and I would be concerned about it being crushed when the U-bolts are torqued or over time.
Been working on it over the past few weekends, but got a lot of work done this weekend. It's the start of my drawer and spare carrier set up.
Open ...
Closed ...
Are the tire tie down points through bolted to the floor? If not, would strongly suggest doing so, in fact the whole construct should be anchored to the floor. I like the beefy looking strap.
Cheers!Yep, hit it with some WD-40 or PB blaster, let it soak and GENTLY try to move it. There is a spring in there that needs to compress, be patient.
2” wheel spacers are needed @GodwinWhat are your plans for the front axle to match the width?
I have an 80s rear and stock front axle with brakes but added 2” wheel spacers up front.Can the IFS hubs be used with the stock brakes?
I want to do this 80 series rear but I don’t want a full System revamp. I’d like to retain as much of what I can as possible.
forum.ih8mud.com
