Hojack
♠️Project Snowball❄️
- Joined
- Aug 9, 2016
- Threads
- 113
- Messages
- 4,582
That art behind the 60 looks like California breaking away into the Pacific
Confirms that black carpets look good. Ordered a grey carpet kit and going to have it dyed.Started putting the B&T rig back together.
J
@Godwin So you had the flat blade end screw as tight as you could get it? Crazy if dropped right out like that. Glad you were able to pull over without an accident
Thank you for posting this. I'm heading out to grease mine now.What is shown is after I tightened it as much as I could. I used a drag link socket on the relay rod end.
I installed these rod ends about 3 years ago and apparently failed to grease them and I'm thinking over time the ball and socket wore enough over time to become loose. This points to a real need to check and grease these parts regularly. I had no warning that this was impending, no extra loose steering, nothing.
I’ve heard the concern here on Mud that you can overgrease the rod ends and bust out the seal on the boot. Obviously some grease works its way out over time as the suspension flexes and the ball and socket experiences load forces. But I think one pump of a grease every year is probably the right ticket, yeah?What is shown is after I tightened it as much as I could. I used a drag link socket on the relay rod end.
Based on your experience posted earlier, I just got back in from greasing my steering components. One pump for each zerk fitting. Went ahead and topped up my suspension while I was at it, and did a quick run-through of the undercarriage to make sure that everything was properly tightened, etc. Checked all of the fluids (ps needed a dash of ATF, otherwise all was good). Took the old girl for a spin and she ran like a top.Tie rod end boots fit tightly and can be blown out by too much grease. Just watch carefully as you pump in a little and you'll see it expand. Relay rod end boots fit more loosely and are less likely to be blown out by too much grease, but still don't over do it.
What roof bars are those? Looks great.Took the fam to one of our favorite spots on the river. No fishing this time, just some swimming and cooking over the fire.
Rear speakers:
Its a bracket from a fj62 that goes in that same spot. Theres another plastic bracket that mounts to this one that the speaker is supposed to actually mount to. I didnt get that bracket and it was a lot of extra work to get the speaker to mount to this metal bracket. I just picked this one up used out of a fj62, if you want to add cargo speakers and make life as easy as humanly possible, get the entire assembly from the 62. This metal bracket, the plastic frame that mounts to this, and the speaker grille. I had to make the little S bracket that connects the bottom. It was pretty easy, you just drill a hole in the body right there and use a button bolt or something to attach itWhat is this bracket? Is that something that was already there from Toyota, or something you made/found?
