Arrogant me. I apparently successfully messed it up.
The ugly thing on the early BJ7x is: You need to undo the brakeline to remove the caliper and brake backing plate.
There is a joint way thingy riveted (!) to the back of the brake backing plate where the flex line connects to a short hardline again, which connects to the caliper.
I undid the short hardline in that joint way first and removed the caliper. Only to note later in the process that I had to undo the flex line from the hardline on the axle in order to remove the backing plate. Two good chances for the old flared tube ends to f* leak.
And yes: The joint on the hardline across the axle to the flex line (47314-60160) failed on me. Can't get it sealing any more.
What a stupid construction.
Wheeling next weekend: Canceled
I likely need a new hardline from the distributer above the diff along the axle to the knuckle: 47314-60160, which of course is discontinued, as well as 47314-60161 for the later models up ton1990.
Neither partsouq nor amayama nor euro4x4 has any of the two.
Am I screwd now?
I'm that pissed... Don't even dare to start the knuckle job on the RH side...
Three questions now :
Is there a trick how to seal or fix a leaking flared brakeline joint?
Does anyone know of a replacement for that hardline across the axle?
Anyone a proven conept how to improve that stupid construction?
I need help, guys. Thank you for any suggestions.
Ralf
