What are you working on? (11 Viewers)
Using the current circumstances to finally dig into my "new" 1978 vintage 8274. Bought it from the original owner out in western PA. He used it on an old Scout. He sold the Scout a long time ago and kept the winch in the garage. Winch works great but I have a little freshening work to do before mounting it to the FJ40. The steel cable had some real stories to tell so it was the first to go. Next, I popped the top to see if any /how much oil was present in the housing. Turned out to be ~1.5 ounces. Enough to bench run but certainly not enough for field use! Even though I could have put in fresh oil, buttoned it up and mounted it, the look of rust on the brake got the better of me. So I decided to take the brake off and give it a soak in Evaporust. And that's where the fight began. Most advise that before removing the circlip that retains the outer brake housing onto the shaft, you should secure the front and back of the housing with a vice grip to keep it all from "leaping" off the shaft from the spring tension kept at bay by only the circlip. So, I was prepared to stop the explosion of ball bearings and other bits as I carefully removed the circlip. After removing the circlip, nothing happened. It took a week of PB Blaster soaking, tapping, heating and coaxing with a gear puller to get the rust to let loose of the brake assembly. Finally got everything off last night and into the rust removal bath!
They are camping fanatics too. Weird seeing BMW/'s and Mercedes towing pop up campers. They are serious. And really just good people.
^^^ Yes, not Germans, but when I was in Amsterdam I had a conversation with my dutch colleagues about the term "glamping" and what it meant :rofl:
^^^ This - I took 8 years of German and at one point was actually fairly fluent. I wound up in Germany a few years ago for business and tried my damndest to speak German. Granted, I was rusty - but within one or two sentences they'd just stop me and say "I speak English" and we would go from there. Of course, once everyone got nice and drunk at Oktoberfest, it became a game to make me try and say things in German so everyone could laugh at my "American Accent," piss poor grammar, and incorrect word choice. Humbling, but a lot of fun!
Just learn Ein Mass and hold up your thumb and all ist Gut!
Using the current circumstances to finally dig into my "new" 1978 vintage 8274. Bought it from the original owner out in western PA. He used it on an old Scout. He sold the Scout a long time ago and kept the winch in the garage. Winch works great but I have a little freshening work to do before mounting it to the FJ40. The steel cable had some real stories to tell so it was the first to go. Next, I popped the top to see if any /how much oil was present in the housing. Turned out to be ~1.5 ounces. Enough to bench run but certainly not enough for field use! Even though I could have put in fresh oil, buttoned it up and mounted it, the look of rust on the brake got the better of me. So I decided to take the brake off and give it a soak in Evaporust. And that's where the fight began. Most advise that before removing the circlip that retains the outer brake housing onto the shaft, you should secure the front and back of the housing with a vice grip to keep it all from "leaping" off the shaft from the spring tension kept at bay by only the circlip. So, I was prepared to stop the explosion of ball bearings and other bits as I carefully removed the circlip. After removing the circlip, nothing happened. It took a week of PB Blaster soaking, tapping, heating and coaxing with a gear puller to get the rust to let loose of the brake assembly. Finally got everything off last night and into the rust removal bath! View attachment 2259097 View attachment 2259076View attachment 2259077View attachment 2259078
Tuned in and watching for updates!!!!!
Figured this might give you guys a laugh...
Last night I am out in the barn painting springs. I ended up with a set of TJM front and Dobinson rears, so flat black it is. I've got one of the springs hanging from the hook of a bungie cord, this one being number three of four. So I am working my way around the spring, painting away, when the spring start to rotate. Not spinning from the bungie cord it is hanging from, but rotating around the axis of the coil itself. And damned if it does keep on rotating, spiraling itself right off the hook and onto the ground! Took a couple seconds to complete the deed, and I stood there dumbfounded at what I was seeing. So much for that fresh paint job :lol:
My pressure washer died when I was cleaning my transmission housing in 20 degree weather last winter.
I finally got around to working on it. Turns out it dumped the oil from the engine and seized it.
I had bad luck with the Briggs engine and always wished I'd sprung for a Honda.
Found a Honda 160 online for $120. Cost me around $150 shipped.
It arrived in 2 days - today. It was a perfect fit and only took about 20 minutes to bolt up and fill with oil/gas.
Now to get the house exterior cleaned!
got some lights from toyotamatt and gave in to a little obsessive compulsiveness and started swapping stuff around on the dash of the '75 to get more of the "correctness" back, which stemmed from using a '77 wiring harness instead of the '75.
first order of business was to replace the '77 brake, erg, seat belt warning light array with a correct '75 brake warning/parking brake light ....albeit in the wrong spot....for now.
like most..if not all 40 series, the green lense for the dash knobs was removed long ago so that the ever so dim bulb even had a chance of providing any illumination on the knobs...well, apparently matt offers direct replacement green led bulbs, and they are pretty darn bright. i also orderd on for the heater control light, but my housing needs the ground wire reattached before that one will work again.
also ordered his super bright blue light for the high beam indicator light in the cluster. additionally he had a new switch for the parking brake light, once that arrives, hopefully tomorrow, i'll pull the cluster to swap that light, replace the erg light thats currently residing were the brake warning should be. i can then install the new bulb and holder for that light..using an led in that one as well. meanwhile the non-functional erg warning light will then take its rightful place to the lower left of the steering column were it should be.
A bit of repair work on a transaxle housing. Stud pulled out of its threads, drilled it out and put an insert in - which was too long, so had to mill it back down flush.
Slumbering away in the shop. It was such a nice day, I was going to drive it yesterday, but the battery needed a charge. :meh:
If it parks outside I like the solar chargers to prevent it dieing.
Wow! That green light is a huge improvement! Definitely getting one of those, thanks!
New weight loss plan...eating everything in sight wasn't working....so I've moved on to cutting off unused parts...its working well.
Me and cutoff wheels have an understanding.....they cut, I bleed....just checking this morning to see if that agreement was still in place .
Worst part is the ruining of a pair of gloves that just got to the real good fit part of their lives.....or at least the left one.
luckily its not the booger hook.
