I found this in History of the 00 Tundra & 01 Sequoia 2UZ-fe:
Connecting Rod
The sintered and forged connecting rod is very rigid and has little weight fluctuation.
A weight-adjusting boss is provided at the big end to reduce fluctuation of weight and balance the engine
assembly.
The connecting rod cap is held by plastic region tightening bolts.
The connecting rods for the right and left banks are placed in opposite directions with the outer marks facing
the crankshaft.
The connecting rod bearing is made of aluminum alloy
Do I understand you correctly; your friend is saying ONLY series 100 have forged connecting rods?My source is someone that works for Toyota corp. in the technical training dept. So it's probably wrong.
I agree!I have been back on google and have found out some more, there is no mention that there are different materials used for any UZ engine, in fact the 2UZ and 3UZ use the exact same con rod, the 1UZ is different and it is stronger. The reasoning behind the weaker con rods was they increased the bore size and not lengthened the stroke to achieve the extra volume. The thinking is that Toyota lightened the Con Rods because they fitted heavier larger pistons and to help counteract this the lighter con rods allowed the engine to rev higher to make up for the larger bore, this is one of the reasons that TRD stopped making the supercharger kits. So I agree that they are all sintered and forged, but all are weaker than the 1UZ ones.
From a link in post #50 Million Mile Tundra: The Tear DownPaul,
Where did you find printed info that 2UZFE was manufactured in the Alabama plant?
Looking at the wiki history it doesnt show evidence of any 2uzfe being assembled, produced there. Could be bad info-as sometimes gigo on wiki.
Toyota Motor Manufacturing Alabama - Wikipedia
Also here is a list of worldwide mfg plants and products.
List of Toyota manufacturing facilities - Wikipedia
It was the night shift on March 28, 2007, at Toyota’s Huntsville, Alabama, engine plant when the Beast’s 4.7L V-8 began life as a non-descript piece of cast iron. Machined on site and then transported on a line around the facility, the engine was quality-checked several times before making its way onto a shipping crate bound for Toyota’s San Antonio, Texas, assembly plant. The engine was one of several thousand the facility would build that year.
When the plant opened in 2003, it only built the 4.7L 2UZ-FE engine and was the only facility outside of Japan to build a V-8. Being a new plant with a small group of employees helped create a family atmosphere with quality being the main focus as they had a lot to prove to the bosses Japan."
