- Joined
- Apr 30, 2012
- Threads
- 79
- Messages
- 426
I have an extremely odd brake issue. It started out a couple of times when I went to hit the brakes it went to floor with little resistance and zero stopping. I quickly pumped the pedal and had full strong braking. As you can imagine this was quite alarming. I checked everything I could and found some questionable vacuum lines. So I replaced everyone on the truck. A few days go by and it seems to have fixed it. Then it happened once again. I noticed that it was happening at slow speed low RPM thankfully. So I started digging again I initially thought maybe the booster went bad again. I had replaced it about two years ago. But it was passing all the normal testing. Then I was thinking an intermittent issue with the check valve. So I swapped in a new one and immediately was able to get the failure. Then this got me thinking it has to be something else. Especially since every booster failure I have every experienced resulted in a very hard pedal. Then the fact that the pedal is going through full travel to the floor with little resistance. Well yesterday I figured out how to replicate the issue every time. If I slowly apply the brakes it will go to the floor. If I apply the brakes at a moderate to fast speed it works as it should. Now this has got me thinking something is wrong with the master cylinder. Is there a way the seals could fail to cause this? It’s really about the only thing I can think of at this point. It kinda makes sense that the extra speed would build pressure fast enough to push against the seal and make it work. Any of y’all have any thoughts or experience with such a issue?
