weight of 2f or what size engine stand
Get one with a "U" shape to the legs, the "T" shaped ones make handling a F/2F a little scarey:eek:
Mine is rated 1250# but has the "U" shaped legs.
GL
Ed
Have fun bolting it up to the stand.
easy if you take the top off the stand then bolt it to that first... then just lift the stand up to the top.... lower down and the only thing you got to worry about is the stand not hitting the cherry picker... worked for me...
btw thats another Ed trick... :flipoff2: he is a real tricky guy...
With out modifying the arms, I have only seen one 2F bolted to an engine stand using all 4 bolts. An that was Bulington's picture. Three bolts is not a problem but that 4th one is not going to happen without some mod work. I have three engine stands and three different brands. LOL!
I had no problem getting all four on mine.....:confused:
Still working on some "Chefs" tickets for you;)
Ed
It's possible. Took me 15 min to figure it out but I did it. 4 bolts. You don't use the arms on two of them. I think it's the top two. You just use the arms as big spacers.
But my head hurt from thinking so hard.
Harbor Freight special stand and easily got all 4 bolts in AND used all four arms! :D
That is exactly what mine looks like. Got all 4 holes lined up. My stand makes me nervous though so I am thinking of getting a U shaped one.
Coolerman.. does your stand seem sturdy enough? Mine seems to sag a bit at the spindle. I have my engine hoist in the same position as yours helping to support some of the weight of the engine.
I was very nervous around it for the first two weeks it was on the stand, but after I realized it was not going to fall off I stopped worrying about it. :D
It has been 5 months now and it's STILL on the stand. I have moved the dang thing all over my 1 car garage and it has been pretty stable.
Yes it does sag a wee bit but not enough to worry about. I would recommend this stand to anyone. :cheers:
Tried mine the way it's pictured above. It would not work. Could only get 3 bolts in. Has to be something with it being so cheap.
This is how mine is set up. Note pre gayness
