WARN 8274...show what ya got! (11 Viewers)
real life use. this thing straight rips.
started pulling me up the tree. 🤣
We MUST know the backstory please.šŸ¤”
female driver. 🤣
this was a volunteer recovery through Offroad portal.
i don't know them. they were unhurt. it appears that they got into that soft shoulder and 3/4 rolled into the trees.
it probably took on some more damage as we rolled it back over. but it fired right up.
there was another rig there and it took both winches to get up the super soft bank.
it was too dark to get good vids, sorry.
i dragged my rope on the ground, it's probably ruined. 🤣 :flipoff2:
@gnob I forget, does your 8274 have the stock motor or have you upgraded?
it's got the xp update.
thing pulled like a train and had zero thoughts about stalling.
i maybe could have pulled it solo if i had an anchor. that's my typical mo if im pulling something heavier than my rig.
There are things heavier than your rig... My 40 tips the scale at about 4700 lbs empty. I could easily be over 5000 between me, hiking boots, and a small tool box. Add in a couple passengers and it'd soon pass 5500 lbs.
generally everything is heavier than my rig.
im weighing in roughly 4600 dry. im right about 6k fully loaded.
@gnob I actually have seen your Warn videos in the past, just haven’t commented on them. Really excellent videos!šŸ‘šŸ‘šŸ‘. Good work.
Here you go. He has 3 videos. This is part 2.
I bought a used Deluxe bar and modified it to fit the 8274.....you need welding skills to accomplish this.
The biggest problem is the winch motor wants to hit the grill so you will have to add about 3 inches or so to ARB
The first thing I did was bolt the 8274 in the ARB and using a jack and jack stands to see how much I needed to add length wise to the ARB bumper...had to cut and bend front support bar as well...
Any more details on the modifications necessary? It looks like you notched the front of the Deluxe to move the 8274 forward? And then added reinforcement plates to the mounting bolts? Plus the modified front support bar?
Nice work either way. It's a killer setup! Jealous of your fab skills.
