I have received many requests for this sheet. Probably should have done this long ago. These two images will help those taking on this swap to pinout the IH1 and IH2 connectors that are located behind the glovebox and serve as the main connection to the vehicle harness and vortec harness. My swap was done on a 1994 80 series which uses a separate computer to control the transmission. The later 80s had the TCU built into the engine ECM so they won't have the 3rd plug (IH3). The IH3 is pretty much eliminated on those vehicles that have it unless you want to add in the gear indicator on the dash.
**please note these images apply to the '93/'94 model year trucks**
To help interpret colors, i used the same method as used in the Toyota EWD. Example: 'R - G' would be red with green tracer.
IH1:
IH2:
When I did my swap I relied heavily on the Vortec ecm diagram that is posted on E38 ECM Connector Pinouts - https://lt1swap.com/E38%20ECM%20Connector%20Pinouts.htm
Enjoy!
IH1:
IH2:
Enjoy!
