- Thread starter
- #41
NEW : Next Generation Fuel Cut Solenoid ....
Dual wire's / 2 wire TYPE w/ Correct TOYOTA LAND CRUISER
2F Engine Specific Design, 2 pin Sealed Double Latching ,
Locking Type , Factory Profile. OEM TOYOTA Electrical Connector
Housing & Encased in the Correct and Safe Originally Designed
Fire / Flame Proof white in color Fabric based wire Loom
That is also Sourced a MADE IN JAPAN
Part # 21062-61060-R
Fj40 FJ55 Fj60 8/80 - 9/87
Also fits a 1/75 - 7/80 with updated Ground wire .
I have Designed a New Fresh idea & Needed parts Solution Update to a
a Very Old and Problematic Basic Minimum Requirements met by the
Aftermarket Suppliers World Wide . The 8/80 - 9/87 FJ40 / FJ60
2F Engine Carburetor 2 Wire Version Fuel Cut Solenoid Part # 21062-61060
was Discontinued by TOYOTA sometime in the late 1990's , When the few
Aftermarket companies picked up the needed parts torch they
failed to apply / install the correct White in Color Fire Proof Wire Loom
, along with the Correct Land Cruiser Specific 2 Pin Connector housing that
matches up with the harness side Green sealed type double latching
.250 Series one
After i dug into this Topic a bit i Discovered the OEM TOYOTA parts maker had
Discontinued the Device side Male Connector Housing attached to the
Solenoid itself originally . Thus forcing the Aftermarket parts maker to Use
a very Common 2 pin NON -Sealed .250 series .one that did not match
the stock Land Cruiser one forcing each installer to cut and splice wires
, or worse ........
I was able to Source the Fire Proof Wire Loom out of JAPAN , with only Minor
Effort , But the Needed Correct Profile Discontinued Connector housing
was a totally different story . I looked and hunted aftermarket for it ,
and finally it came to me , to attempt to contact the original OEM Parts maker
Direct in JAPAN . I got a-hold of them and a lady translated for me ,
after some creative use of the English Language , i managed to convince
them to do a limited Production Run for me . i knew a little about what was
involved during my experience Reproducing the Cluster Meter Round 12 pin
Barrel Connector Project a while back .....
The end product result is nothing less then a Text Book Reproduction Part
that will Meet the Needs of the Later 2 wire Solenoid 2F Engine Land Cruiser
Community ...........
Excuse my ignorance, is this also referred to as the idle solenoid or is that something else?
SOLENOID, THROTTLE VALVE |
How is any of this tech?
You are correct, there is some tech here. But in all honesty it's mostly about you promoting products you sell. It was more a jab at you for consistently posting up close photos in random threads of items you have for sale. Don't get me wrong I am very glad you are here supporting our forum and Land Cruiser enthusiast, I may even need some of your products one day.
Also, I believe a Lumen is a measure of Forum Etiquette
