Update: 5W-30 & Heavier Recommended RoTW (2 Viewers)
Anybody knows for sure that GM after decades of building engines decided to not machine the bearing surfaces to a smooth finish and that is the issue at play?
I find that hard to believe. It is more to do with indeed running to low oil viscosity, higher mileage change intervals, weaker piston rings letting more fuel by, perhaps changes in the lubrication system or increased operating temperature for efficiency. As a result 0W20 is running to thin or gets diluted and it just needs -30 or -40 allowing for some viscosity breakdown allowance.
All in all in a new build GM with that engine I would run the more viscous oil (0W40 or 5W40), what ever they say about it.
Thanks @Julian73
The beginning of that part number was obscured in a picture in this thread.
5W-30 Oil filler cap with white font, 12180-0H012
For future reference, Here is the other 5W-30 oil filler cap, part number 12180-38030, with blue Lexus font that @bjowett found
I am on my 3rd oil change with 5W-30 at 5k intervals. So far so good, as expected.
Oil is plenty dark at 5k
So far so good, it has higher oil pressure, obviously.
At initial start and at idle with the AC on. With 0W-20 idle pressure was a tick below the 1/4 mark
Pontificating is fun though
Toyota’s 3.5 TT with all the machining debris issues has entered the chat…
Yep, could well be the thin oil, short drives and dilution making it even thinner, 10k intervals and resulting metal to metal contact adding to the misery.
TL;DR - They did in fact do a s*** job machining these engines however the 0W20 is still to blame in a sense because it drastically reduced margin of error in operation.
Crappy machine work + low viscosity oil for some MPG gains = recall
I changed my cap as well to 5W30 incase on a long road trip in the future i go to a lubrication place instead of DIY.
I was chastised by the senior Toyota tech at my dealer for replacing the oil fill cap with a Toyota 5W30. I have thick skin and disregarded his admonition.
The type of guy who replaces the cap isn’t typically the type who then goes to deal with a service tech.
I feel like you enjoyed this.
I love the attention to detail with the matching 5w30 fill cap swap. Nicely done.
Oooh, good eye…. Just ordered same
I hope it was in public. Near the red plastic chairs in the waiting room.
Where you do you find OEM Toyota one, or at least one that is high quality?
master tech shellacking NOT included, but if you play your cards right with the dealership...it too can be yours! aMiRItE @stonepa ?!?!
I wonder if there's a 0w-30 cap out there. :confused:
