I wonder if there's a 0w-30 cap out there.![]()
Since Toyota doesn't recommend 0W-30 for the 3UR-FE motor, I doubt you will find the cap you're looking for...
HTH
I figured that. Sorry I meant the post to be kind of "tongue in cheek".Since Toyota doesn't recommend 0W-30 for the 3UR-FE motor, I doubt you will find the cap you're looking for...
HTH
CCN and other 0w20/low wt advocates have now put a bounty on this man. They even know where he works!Some in from a user mtkey on the Tundras.com forum. FWIW
“Interesting to read through this debate a few years after the flurry of discussion happened. I worked at the Toyota plant in AL for a few years where the 5.7 was built. During final leak test operations, the oil pan was filled with 5W30 through the fill neck and spun through its test cycles, which took ~30 seconds an engine. Simulated idle, a few rev-ups, a sustained run period at ~3000rpm, back to idle, off. Every component that oil is distributed to in real-world operation was pre-oiled during assembly (also with 5W30 to my knowledge), so nothing was dry when the test ran.”
I love the attention to detail with the matching 5w30 fill cap swap. Nicely done.
All I know is I'm SOL as far as getting a 0W-30 cap.Anyone knows of a 0w40 or 5w40 cap lol?
I’m thinking about buying a new 0w20 one and sanding it down and using my dremel engraving pen and some paint pens to get 0w30 on there…yeah, it maybe a little redneck engineering but I gotta stay true to my roots I guess.All I know is I'm SOL as far as getting a 0W-30 cap.![]()
This is perfect!Part # 12180-38010 is blank.
Use your fine point on your dremel after using some sort of stencil/sticker. After you get good depth and lettering clean out all the debris. Once dry, use some of your lady’s favorite nail polish and fill the lettering. A razor blade to clean off the excess once dry will have it pop with whatever wt oil you want. Post pics when you’re done.This is perfect!
I just found this out the hard way. Aggravating.Part # 12180-38010 is blank.
Amazon.com: Genuine Toyota (12180-0H012 Oil Filler Cap Assembly : Automotive
Buy Genuine Toyota (12180-0H012 Oil Filler Cap Assembly: Engine - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
No cap. Fr frFunny, I order this twice (second time to see if first time was just a mistake) and both times they sent blank caps. No text on the cap and certainly nothing about 5W30. Annoying.
I ordered the same cap a couple years ago:Funny, I order this twice (second time to see if first time was just a mistake) and both times they sent blank caps. No text on the cap and certainly nothing about 5W30. Annoying.
Yes. Details matter.No disrespect here, but are the oil caps really that special? I will go back to Andy Griffith reruns....
