Original was 275/70/16, which gives 10.9% and that aligns with what two GPS units told me
What do you mean by that? Did you mean to say speedometer?Today, on the freeway, to work, the odometer goes to zero.
With what he described, fixing that might possibly bump him up to 8.5-9mpg.Ok, so we need a thread title change: "How to fix busted speedo?"
Catalytic converters are original. They could be bad, but how to know?How are your catalytic converters? There was a night and day difference on my supercharged cruiser after getting rid of my 250k originals.
Yes, speedometer. Sorry.What do you mean by that? Did you mean to say speedometer?
Edit: You meant speedometer. And your trip meter stopped advancing during that time. And you don't know whether your odometer stopped advancing as well. Correct?
Take an IR gun and get temps fore and aft of the cats. That can indicate a clog.Catalytic converters are original. They could be bad, but how to know?
I’d hate to throw parts (expensive ones to boot) just to see…
Like I said, there’s other factors at play. But why not do it right while you’re at itA lot of trucks running around without being tuned not getting 8mpg. There is an issue. Throwing more parts at it isn't going to fix that problem, you will still have to fix that problem with an ECU.
Check for vacuum and boost leaks, check your O2 sensors, check your cats, etc. There is obviously something going on. If it wasn't like this from 2 years and it all of a sudden happened it obviously isn't the usual.
And is he running stock gears?So am I the only one who thinks this is a pretty silly discussion without a) adjustment for tire correction, and b) no real idea how often the odometer's not turning?
They didn’t design the turbo to run on a factory obdII vehicle. It’s just a giant turbo that spools slow so the stock ecu can keep up, which is a terrible way to turbo a vehicle.Turbo was designed to run on the factory ODDII ECU vehicles.
I am running 91 octane due to forced induction.
What temps should I be seeing before/after turbo?? Just run at idle & check, freeway pull?
