S4Cruiser
View attachment 1696272 Grease Question- once I get to reassembly, is this grease good to pack my knuckles with. It was the only moly grease they had at Napa, I bought two tubes. Figured I could use a grease gun to fill the knuckle through the fill plug on the top of the knuckle.
That should work fine for the knuckles/birfs. I typically use the valvoline stuff which is likely less expensive. https://www.amazon.com/Valvoline-Moly-Fortified-Multi-Purpose-Grease-VV632/dp/B000CQ6L64?th=1&psc=1
You’ll also be better off packing by hand around the birf/inside the knuckle which is quicker. I’ve used a grease gun which works to but never via that small hole.
