Malleus
Far west of Siegen
He has more toys than me
And it did. Thanks for the use.You can use my Tormek. It will put a razor edge on anything.
Don’t feel bad. On Saturday, Jake @CruizerHound used his lathe and precision instruments to do a job for me that Fred @Malleus says could be done with a bench grinder and a couple of skateboard wheels. Overthinking is fun when you have the tools to support your overthinking.And it did. Thanks for the use.
I felt like the little kid that the adults give a mindless task to occupy while they do important stuff on the big machines. I was just grinding and polishing away while @Malleus and Jake used a giant machine with a computer to do something way below its pay grade!
Careful using this on your kitchen knives. It works, but is sooooo aggressive. I ruined my Wusthof Chef knife after about 3 sessions by taking away too much material. Great for mower blades and such, and probably if you stay away from the lower grit. I was naive and just followed the instructions.I don't have one but have friends that swear by the Work Sharp. Not sure how well it would work for a chisel and they are pretty pricey too... but very cool
Knife & Tool Sharpener Mk.2™
The Work Sharp Knife® and Tool Sharpener Mk.2 sharpens every knife and tool you own. The flexible belts, sharpening guides, and a two-speed motor makes sharpening faster, easier, and more versatile than before. Used by the pros, millions sold, never be dull again.www.worksharptools.com
I have quite a few of the Wusthof Classic knives and use this sharpener for them. Works great, just be sure the blade angle matches as they may differ from brand to brand, line to line, knife to knife etc. I rarely if ever user the coarse side.This is good to know. My wife and I bought the Wusthof Ikon Blackwood knife set a couple years ago and I was looking at a sharpening system to keep them razor sharp since we use them 4-5x a week and this was one I was looking at. I’ll do some more reading first.
That's all I use now too. And try to hit my most heavily used knives with the honing steel before every use.I have quite a few of the Wusthof Classic knives and use this sharpener for them. Works great, just be sure the blade angle matches as they may differ from brand to brand, line to line, knife to knife etc. I rarely if ever user the coarse side.
Wüsthof Two Stage Hand-Held Knife Sharpener
Sharpen your knives effortlessly with the acclaimed Two-Stage Hand-Held Sharpener. It's durable, portable, and a kitchen must-have.www.wusthof.com
Very clever!Installed my adjustable panhard bar today with the OEM jack. Bracing the jack against the tire and frame support allowed me to fine tune the ideal length of the panhard.
Get it, it's kinda the gold standard for impacts right now. I guess the first gen was technically the gold standard, but it'll still be everything you need. The Torque Test Channel, on YouTube, tested the 2nd gen impact... I think: linkBeen debating finally getting an electric impact wrench for a while now and trying to get my rear companion flange off my tcase outside of the truck while balancing on the transmission jack was enough to convince me now is the time.
I just ordered one of these since there aren't any local and think 650ft/lbs should suffice for my needs while still allowing me to get it in tighter spots than the mac daddy 1200ft/lbs version.
Anyone have these and/or have any reservations on it?
Milwaukee M18 FUEL GEN-2 18V Lithium-Ion Brushless Cordless Mid Torque 1/2 in. Impact Wrench with Friction Ring Kit 2962-22 - The Home Depot
The MILWAUKEE M18 FUEL 1/2 in. Mid-Torque Impact Wrench w/ Friction Ring Kit delivers the best power to weight ratio, most access in tight spaces, and faster removal speed. It provides 650 ft-lbs of nut-bustingwww.homedepot.com
Either Milwaukee or DeWalt are both worth the money. It kinda comes down to whichever battery ecosystem you are already married into, or if you have room to do both battery systems.
After just removing my crank bolt I might vote for the high torque. I have the Dewalt because I already had those tools/batteries. If you are starting fresh, the Milwaukee stuff seems to be a little stronger. It's nice knowing the tool will do any nut/bolt on the vehicle.
Now along with the big one you can pick up the compact impact and/or a 12v ratchet. That little 3/8" high speed ratchet is nice to have.
