I couldn't help spending 5 minutes running the lift up and down when I got it home. Everyone who saw it had permagrin.Those trailers are tits!
Nice grinder too!
Nice grinder too!
www.swagoffroad.com
SWAG 20 TON Press Brake DIY Builder Kit
20 TON Press Brake DIY Builder Kit Press Brake kit comes unassembled, you do the final assembly and welding.Designed to fit the Harbor Freight 20 ton hydraulic press Item # 32879, 60603 & 70603.Press brake kit includes an adjustable back stop for accurate and repeatable bends. Max Bending Radius...www.swagoffroad.com
I've been eyeing these for a while. Lots of options from swag offroad and curious to see other accessories people share.
www.swagoffroad.com
www.swagoffroad.com
www.swagoffroad.com
www.swagoffroad.com
Or you know, the right size knipex snap ring pliers![]()
That's what i'm asking if you know what model number it is for the right size. I figured you would have a set.
Thank you@uzj100
I’ve really enjoyed the Northern Tool Yellow Jacket jack. I paid $200 since I’m part of the Northern membership program. A lot better than the HF jacks I’ve used. Doesn’t sway and is rock solid. Also has a nice slow release and drops slowly and controlled.
Yellow Jacket Low-Profile Super-Duty Jack 3-Ton Lift Capacity, 4in.23in. Lift Range | Northern Tool
This Yellow Jacket Low-Profile Super-Duty Jack lifts up to 75% faster and lasts up to 10 times longer than comparable standard floo...m.northerntool.com
I also bought some Strongway stands after the HF recall. These are double locking and still not breaking the bank at $20/pair as a member. Been happy with the 3 and 6 ton versions I have.
Strongway Double-Locking 3-Ton Jack Stands 6,000-lb. Total Capacity, Pair | Northern Tool
This pair of Strongway Double-Locking 3-Ton Jack Stands features a large saddle surface area to provide better contact wi...m.northerntool.com
I like the more expensive HF jacks. I have one of the HF cheaper gray jacks and it's ok but developed a leak that I had to fix.Thank you
These are on sale at Northern Tool. 6T/12T at a pretty good price. https://m.northerntool.com/shop/tools/product_200756194_200756194Please provide recommendations on floor jack and jack stands. I like the aluminum floor jacks. Thank you.
