What's the situation with the AC compressor valve head? I assume that's 88320-35H91 compressor?
Yeah I have to source a head before summer. My plumbing is all still in tact from the 3F a/c which did work, but I need to find a compressor manifold/head that will work. Any ideas?
Finally, after months trying to source the right diesel tach I was able to get one from a HZJ75 out of Australia. Utesandparts was able to source me one.
Plug and play, if you can find the tach wire in the engine bay that went to the coil for the 3F engine.
The black wire w/red stripe from the fuel pump sensor goes to the black wire /red stripe from the old coil tach on the 3F engine. (or pin 4? on the cluster, iirc. Also black/w red stripe)
The brown wire from the fuel pump sensor is just a ground, I ran it to the frame.
Also did a fuel pin and removed the factory airbag for a K&N filter. I'd like to figure out a decent box for the filter, but for now this gained me 5psi in boost, just replacing the air filter with an aftermarket. That was a surprise.
I got a spare dash pad too. Mine grew a crack over winter.
not surprising at all gaining boost and how quickly it boosts. I unhooked my snorkel setup to test why a hose was collapsing. boost was instant and way higher. Definitely less safe, but yeah that aftermarket filter flows more for sure.
Looing good!not surprising at all gaining boost and how quickly it boosts. I unhooked my snorkel setup to test why a hose was collapsing. boost was instant and way higher. Definitely less safe, but yeah that aftermarket filter flows more for sure.
nice! Mind asking where you sourced the dash pad? I'm looking for a dark sable one without the dent for the inclinometer ideally but either style could work.Finally, after months trying to source the right diesel tach I was able to get one from a HZJ75 out of Australia. Utesandparts was able to source me one.
Is that 3F tachometer the typical gasser tach that uses a signal from the coil? If so, would you be willing to part with it? I think that is the type of signal my VW ECU is putting out, and should work with the correct resistor.
