Probably a stupid question but how do you shift through the gears? Whie its lifted off through ground?
Right foot on brake pedal, right hand on shifter. Why is it lifted?
Do you guys put exaclty 4 qts back in when refilling or do you put a little less than 4 qts ,drive around fro 20 minutes and check the level then fill accordingly?
I'm about to do this job and was looking at these clamps and I'm wondering if I can put them back on when I finish the fluid exchange or if I need to get new ones ?
The cold mark is just there so you can fill enough to drive it without damage and warm it up for the real reading, the full operating temperature measurement is the one we are really interested in.
you could think of the cold mark as step one and the warm mark as step two.
parked idling will not get you there, 30 mins of actual driving should get up to full operating temperature.
I got it up to operating temperature. The hump was hot. I drove it for at least 30 minutes, 20 miles or so at highway and city speeds. I checked it after cycling the gears and it was lower than the cold indication on the dipstick. It was at cold before I drove it. There are no leaks anywhere.
this is another issue I've been wondering about...
I think I have mistakenly thought that the 'cold' mark on the stick was for when the engine is not running... now I'm thinking the 'cold' mark is for when the engine is running but nothing is warmed up yet ? right or wrong?
SCarolinaFZJ80 is saying the level was at cold before driving and getting up to temp.. then lower after driving around ...
ok.. so the question is was it 'at cold' on stick when not even running or running but just started up from a cold state.. been sitting a while?
I'm curious because I'm no expert but just trying to learn... I'm thinking the level will be higher if the engine isn't running and the ATF has drained back down into the pan ??? then after you start it up and it starts to pump the fluid around, then the level will be lower because not as much is in the pan??? right? wrong?
then after it gets up to operating temp. would it be even lower or higher on the stick ?
if you are doing this fluid exchange and starting and stopping the engine while cycling the ATF through, I'm guessing, based on what's been said here, it's not going to get up to temp to read accurately so ....
after finishing the exchange... and trying to make sure you're putting enough back in there... where should the level be on the stick when it's not running ? at 'cold' or should it be running and at 'cold' ? is there no point in trying to gauge the level when it's not running? I just don't want to go driving around for 30 min not having enough fluid in there while trying to get it up to temp.
10. AUTOMATIC TRANSMISSION FLUID LEVEL
(a) Park the vehicle on a level surface.
(b) With the engine idling and the parking and foot brake applied, shift the selector into all positions from
”P” to ”L”, and then shift into ”P”.
(c) Pull out the dipstick and wipe off the fluid with a clean rag. Re–insert the dipstick fully and check that
the fluid level is in the HOT range.
(d) Do this check with the fluid at normal driving temperature (70 – 80°C (158 – 176°F)).
If the level is at the low side, add fluid.
NOTICE:
Do not overfill.
HINT:
Wait about 30 minutes before checking the fluid level after extended driving at high speeds in hot weather,
driving in heavy traffic or with a trailer.Is that complete enough?
job.
Dealership is offering a drain and fill for $110. They are saying all the right things too "you dont want to flush it, you will run into problems. you just want to drain and refill". "we don't use any heavy cleaners on older models"
Is there any reason I should do the service myself?
