as usual.......
No mo stinkin leafs! ;pVery nice work. I want to redo my crossmember and may copy your set up. Doing my 60 later this summer, so thanks!
Did RuffStuff sell you the Jonny Joint?
Looking forward to the rest of it.
Looking at your crossmember. Are you going to bolt it in or weld it in.
If you weld it. Dont forget to take into consideration the future removal of Tranny and T-case.
whats a pain in the ass regarding the joint assembly? I can imagine that welding on the shell will shrink it, requiring a bit of force or honing to get it together... even shrinkage as small as a few thousanths with make re-assembly a bitch... typical press fit interference is .001-.003", and on the upper end of that will require a big hydraulic press to get it together.
Its not unusual for folks that are building lots of A-arms or other suspension pieces with uni-balls or johnny joints to machine a bronze puck to fit in the shell, to help keep the ID uniform when welding. even then some final honing will be required.
as usual.......
You built 2 link bars okay. Fab 2 more, buy some longer shocks, coil springs & perches from a TJ, build a truss on the housing & yer thereNo mo stinkin leafs! ;p
looks good cam, BTW, don't ever say gettin er done again,![]()
looks good cam. I will be building one very similar. Not sure if I will use a johnny joint though. Let us know how that works out.
i almost didnt, but then i saw my brothers when it flexed and it seems to bind up pretty good, and i thought the joint would ease some of that. its probably not a necesity. sp
Howdy! I used a double joint on the front of mine to allow slight axle movement front to rear. I put a fixed bushing on the cross member, and then made a 4" shackle to drop off of that. My "Y" arms join a few inches before the shackle and they are mounted onto a heim joint I picked up for about $20 at the local John Deere dealership. They have some nice BIG stuff there, like shackles, D rings, chains, PTO drives, etc. Johnlooks good cam. I will be building one very similar. Not sure if I will use a johnny joint though. Let us know how that works out.
i got it here, probably not the cheapest or the best place but i was in a hurry to get it started and they had what i needed,
Sam's Offroad Equipment-Your source for Warn Winch, Teraflex, Rancho, Service and Installation i think it was 45 bucks or so. shipping was ridiculously retarded $$$$ and i thought sor was bad
