- Thread starter
- #41
and so as they cooled i tried to find some spray paint, wanted all black but only found 1/8 of a can in black and i had some red so i thought, why not, itll be trashed and covered in mud most the time anyway
Why the shakle type mount up front?
I realize it is designed that way, but why? Wouldn't it still allow your axle too wrap the full motion of the shackle movement?
So it can move with the travel of the axle on the leafs.But it won't let the axle roll.![]()
Howdy! Yea, this is a great working setup with the shackle. Ya did good on choosing some super tube for the main sections. Mine is very similar, and since I have double LockRights, I run a lot of 2wd low range. I can hammer the throttle and the pinion does not climb up at all. Two years ago I did a nasty hill climb, but I forgot to slip it back into 4 low. I hardly noticed the difference! Much better traction and control with a good anti-wrap bar. Certainly worth the time/work/money. You're gonna luv it! Good job. JohnIt would just pull the shackle down and stop axle wrap. i have mine like this and works great.
thanks, im hoping for some good results. does your shakle hang straight down or is it a little tilted like mine? just wondering if i should move the crossmember back a tad or leave it.
any ideas. probably doesnt make a diff. i dont know
I see I am not the only one who uses a vise on the garage floor.![]()
Howdy! I don't know how much upward force the arm can create in a worst case senario, but I have my shackle running pretty close to striaght up and down. I also put my top shackle mount centered under my cross member so it could not create any twisting action on the member. I don't know if yours might do that with the short stub you have going out sideways. Mine is a little longer than yours since I have more room down there on a Piggy, but I tried to leave enough room behind the transfer case to add a 5 speed and/or a toy box when I hit the Lotto. In 2000 I broke my rear pinion between the inner and outer bearings, due to axle wrap/stupidity. I think our design is the best overall to allow maximum flex and wrap-control. Most of the failures I have seen have been due to using no shackle on the front of the arm, or using thin walled tubing for the arms. I have also seen one fail at the welds on the front of the arms. The builder just didn't realize that the stress there is pretty crazy. The lower arm is pushing forward, and the upper arm is pulling back even more, as it is farther off the centerlineof the axle. With the mondo tubing you have, you can really crank up the heat and get some great penetration. Johnthanks, im hoping for some good results. does your shakle hang straight down or is it a little tilted like mine? just wondering if i should move the crossmember back a tad or leave it.
Would 2 inch tube, 1/4 inch thick be good enough for the arms on this type of traction bar?
