- Thread starter
- #441
This rear main has a felt lip on the outside. I have one from cruiseroutfitters with no felt. Just rubber. I’m assuming this felt version is for an older 2F iteration? Maybe an F engine?
View attachment 3191380View attachment 3191381
When I swapped my diffs and did my rear wheel bearings I was having trouble getting the axle into the bearing. I ended up destroying the one cruiseroutfitters sold me and went to oreilly to source an other one. All they had was National. Oh well I thought, better than nothing. It was a koyo in the package. Sweet!FWIW, if you choke on the price of the RMS from Toyota, this is an alternative.
If you buy a National Seals (Federal Mogul) this is what shows up in the box:
(says made in Mexico, but NOK brand and exact same part # as on the Toyota-bagged, so who knows. It's identical to the OE seal. Price is about $25 less)
View attachment 3193077View attachment 3193078
stop.........
- please PM me and make a brief time for a shop hot line tech-time live call .........
- this paticulal WIPED crankshaft keyway issue and topic was a major problem for certain TOYOTA engine family's back in my dealership days as both shop foeman and team leader in the service dept. i have remodied more of these exactr issues then i can count successfully ,
HOWEVER ,
you ONLY get 1 chance to get it 100% spot on accurate , or your F#CKED ! \
- i indeed learned quick after my first several failed attempts , until somebody i referred to as TRD-MOSES skooled me correctly , i was in my early 20's he had lot's of grey hair and a big bushy beard , so hence my nickname for beloved John , whom has long since passed away , he was a lifetime Toyota Master technician , and started is the early 1970's at Brown's TOYOTA CITY in Glen Burnie Maryland , my 2nd summer internship Rodeo ........
- this is a outside the BOX HYBRID approach , but WILL if prescribed steps by Steps are followed to the T , save your 2F from certain DOOM ........
i am here to help you on this topic in any way i can ...
kindly matt
@ToyotaMatt Can you share what "Outside the Box HYBRID" fix is? I have a similar issue (although maybe not as severe as a Key problem, but the HB wasn't as tight fitting on the crank nose), and I am curious what your fix is. I was planning to install a new AUS HB hoping to get a tighter fit on the nose and fit a new Key with some JB Weld to keep it from moving in the key way.
I’ve had my hands full the last few months. I’ll try to give you a call soon.i have yet to speak by tech hot line to @cps432 regarding his KEY WAY issue , i came across this unique phenomenon many times back in my dealership days , ill explain in more detail here for sure ........
ill circle back as soon as time permits and get all thingstechnically technical about it ...
it's a KOOL solution , a person with a moderate to high skill set level can make happen ...
Thank you! This is the heaviest mechanical work I’ve done myself. I think… I haven’t done much of this work before, though I have brainstormed it for a long time. I’m glad you’re getting some ideas.Great work. This is really inspirational to me, it’s far beyond what I’ve ever done and gives me hope for rebuilding the spare 2F I have.
This is my exact sentiment here and why I’m on the fence. I am confident in my understanding of how everything should fit together and how to use the tools. But like you said it’s the experience that I lack… being a professionally trained woodworker who makes fine stringed instruments requiring exact measurements to function, I do have more general experience than a lot of people in the areas of creeping up into tolerances and whatnot.The problem is, (with anyone doing this for the first time) is that they have zero experience doing it. They haven’t been shown how to do it correctly (cutting seats) and their first attempt is going to basically be blind - hoping the FSM instructions are adequate.
There won’t be a chance to practice on a few first, to get the hang of it and improve on technique. Nope. It has to be perfect right out of the gate with zero tolerance for a screw up.
It’s not like a person can get away with getting the hang of it on valve #4 after kinda botching 1-3. They all have to be perfect.
Maybe (maybe even likely) a complete head overhaul can be accomplished successfully by a careful first timer, but the hazards are many solely because its all uncharted territory.
But if doing it yourself is the only option — then you gotta do what you gotta do. Just be extremely careful.
That’s like aromatherapy for your garage… and 5 gallons of simple green.
home built hot tank, hot damn! am i correct in thinking the crab boiler is under that stack? any charring or burning of the spacer lumber? also, how long does that tank of 'pane last in use? good fortunes with your rebuild by the waySo, over the Christmas/New year holidays I made myself a hot tank and boiled my engine block out. It worked pretty well and only cost about $75-$85.
I found a 55 gallon fruit juice barrel at a local hardware store. Picked up a crab boiler off Craigslist (surprised to find a crab boiler in Montana) Got some cinder blocks and 5 gallons of simple green.
I had to stack the cinder blocks and some 4x4 lumber to support the barrel. The engine hoist is holding most of the weight of the engine block. It took several days to do the head and block. I also did the transmission cross member and the bell housing. A lot of the paint bubbled and scrapped off easily. The carbon basically rinsed off with a spray bottle. All in all I think it was worth it.
I also picked up the stuff for an electrolysis tank. I have yet to set it up and use it, but I’ll be doing that at some point. View attachment 3218636View attachment 3218637View attachment 3218638View attachment 3218640View attachment 3218641
You can ask anyone I work with and they’ll tell you I’m OCD with my work. I count every stroke every time. I am cognizant of my body mechanics and how my ergonomics effect the work and I go to great lengths to minimize my imperfections.
When I’m learning a new skill I think about how I would teach someone else to do it and it forces me to think more critically about what I am doing. I “think” I can pull this off based on literature and some tech videos I’ve found.
Lol….
don't doubt your capabilities guys, we have a young lady in here who's done what you are working on n considerably more. apparently, she'll NeverGiveUpYotas. find her build thread n check it out for inspiration, it's bad @$$Similar to what you’re saying, the “machine shop” work part of it scares me. I know some of that has to be VERY exact. Good on you for doing it though, and when it comes time for me to do it I’ll probably message you haha.
That being said, I did have a spare head rebuilt last year, so that part is done. I think it was $450 and it was done at a place that’s been working on 2Fs for 30+ years. I know the lower end is going to cost more so I’m thinking I have them clean up this spare block I have - clean it, level the top, gone the cylinders, and maybe polish the crankshaft. Right now I’d like to do the rest, but we’ll see. I just want a solid, completely rebuilt 2F to drop into my truck at some point.
