SC-Cruiser
Just finishing up the complete rebuild and conversion of my front axle to disk brakes on my 1971 FJ40. I am at the point of replacing the tie rod and relay rod ends, repainting the rods and also wanted to replace the clamps and associated hardware since they were rusty and the threads on the bolts were worn out. I have so far been unable to find the right bolt for the tie rod clamp.
Looking at various Toyota parts sites (Partsouq seems to have the best diagrams and part number references) the original bolt for the tie rod clamp bolt was 91111-41040 but it has been replaced/substituted by 91111-51040 so that is what I ordered. When the parts came in from ToyotPartsDeal the bolt was 5mm shorter than the old rusty OEM tie rod clamp bolt. The new bolt was in fact the same length as the bolt for the smaller diameter relay rod clamp. For reference the OEM tierod clamp bolt is a M10x1.25 45mm long, the OEM relay rod clamp bolt is M10x1.25 40mm long
I have searched this forum up and down and have been unable figure out if ToyotaParts Direct sent the wrong bolt or if indeed the substituted bolt part number 91111-51040 is indeed the wrong length . If anyone knows the answer to my dilema or can point me to the correct bolt for the tie rod clamp. I know this is a small picky detail but for some reason I cant let this one go.
