Howdy! Are you using a MIG? If so, there are several posibilities. Bad wire: it can rust/corrode eventhough it is indoors and protected. Look it over for little random dots on it. May need to replace the tip on the handpiece as it can bind up on the wire or it can loose contact with the wire if you have cleaned it out too many times. You may have a kink in the sheath between the handpiece and the welder. This can be very difficult to find. It will bind on the wire only when it is in just the wrong position. Bad gas; straight CO2 will work OK a lot of the time, but some steels really need the right mix of Argon. Wrong size wire, if your doing heavy work with 0.023 instead of 0.035. You may need to clean the contacts inside of the handpiece and/or the main breaker. I may think of more in the next few minutes, as I am on the way out to go weld on my new Saginaw box support bracket that I am making from scratch. I will be doing a thread on it when/IF I ever get it done.Hope you get it sizzling smoothly soon. John
P>S> OOps, here's another one:dirty/loose drive wheel not pushing the wire out to the handpiece. DUH!
Thanks inkpot. I think I figured it out last night - here is what I did.
1) Cleaned (read ground to bare, clean metal) all surfaces to be welded. This did NOT help.
2) Ground my ground area down to bare metal. This did NOT help.
3) Grabbed a random piece of metal to weld. This did NOT work.
4) Hmmmmm - checked wire feed - it was good everywhere.
5) New tip - did NOT help.
6) Cleaned gun end (whatever you call it) - did NOT help.
7) Wire speed up - did NOT help.
8) Wire speed down - did NOT help.
9) Power down from 4 (max) to 3 - oooo, this worked.....wait, nope, did NOT help.
Now - good welding was intermittent - every now and then my welder would burn long and strong...maybe better than it ever had...then it would crap out.
I was using 0.035 wire.
10) Switched wire out to 0.023 wire - this WORKS!
Hmmmm - I think I have bad wire. I'm about 2/3 of the way through a spool of cheap ass Harbor Freight wire. I'm going to stop by Lowes on the way home and pick up some better wire.
I did take the time to clean up all my weld areas so once I get the new wire and hopefully get this problem fixed I can just weld everything up and call it good.
On a separate note - I did install my planed manifolds - they went on very nicely! Also installed the carb isolator with two new gaskets from SOR. The bottom gasket had to be carefully removed as it was a piece of $hite. I gouged the isolator a bit but hopefully the sealant I used (gasoline resistant) will work. It appeared to seal up good.
I put my old carb on and DANG!!! it is dirty compared to everything else. I don't have time to clean it well so it will just have to stay dirty for the time being. I know the engine as a whole won't be clean for too long.
I'm picking up some fluids for my install this weekend and getting a tag for the truck. I couldn't find my dang title last night - that means I'll have a fun time at the DMV.
