Are the clutch hydraulics tied into the brake booster system at all? I'm trying to figure out how you could maybe get a vacuum leak when you disengage the clutch...
I don't think so...
Lets see...clutch line goes from slave up firewall, screws into hard line which goes up firewall, turns a 90 and then feeds into the cab...IIRC...so there shouldn't be any issues there.
What I think might be most telling is the Piggie most often won't cut off in stop and go traffic - it cuts off after I've been up to speed for awhile 'cruisin' and then put in the clutch to slow down for a turn/stop.
Yeah I didn't think so, the clutch is independent hydraulically and doesn't need a boost.
Presumably you've been decelerating a bit when you push the clutch in to downshift. And obviously you're letting up on the gas. Sounds like a fuel / carb issue. Just don't know what....
Check to make sure the choke valve is opening all the way...
The carb needs cleaned out. It sat for a while and the gasoline & dirt turned to pudding inside the small passages.
I might just try the carb rebuild myself - the kits are about $30-60. If I F it up I'll ship it off to Jim or ACC.
I have found two sources for rebuild kits.
Cruiser Outfitters (Kurt) for $30
CCOT for $60
I read that Kurt's kit was better quality but the CCOT kit had more parts...I'm leaning towards the CCOT kit just b/c it has more parts but I haven't decided. Also, Kurt's kits along with a couple other sources break down the kits almost to the year, where as the CCOT kit includes several years per kit...
Any suggestions?
