theglobb
- Thread starter
- #1,521
I usually consider myself the king of maintenance, grease my u joints every oil change, check all fluids every 10,000 miles or so, etc etc. I am revoking myself of that title after this... the troopy started stumbling over itself yesterday and I had no idea what was going on, it wouldn't even drive up a hill. Got my trusty zupup and a buddy of mine to tow it a mile home. I had no idea what it could have been, figured air got in the fuel system somehow and then I realized, I haven't changed my fuel water separator/fuel filter ever. Like I put it on when I was 18 years old, before I drove across all of America, and now I'm 21 with a whole different engine installed in it.
Well needless to say that was the issue as you will see in the pictures below. I am amazed it didn't fully stop the fuel flow sooner
Put a new filter on and my issue has been solved, plus quite a bit more power I haven't had before. I'm assuming the multiple "worms" I pulled out of the filter element are algae if I had to guess. Or who knows maybe someone put worms in my gas tank
I ordered some 24v glow plugs last December, I have them installed to hold the compression in obviously but I am just not skilled when it comes to electronics. I'm sure I could do it, but when your dad is an electrical engineer... might as well wait for then next time I go home and have help with it, it'll be 10x better than I could ever do on my own. For now the block heater works greatCan't say enough good about having a manual glow plug switch. Momentary toggle switch low left of your steering wheel on the dash which activates a ford/generic cheap starter solonoid sending 12V or 24V to the glow plugs. You'll figure out how long and when you need to hold the toggle switch on before starting. For the 3b in temps above 70F don't need to use it at all. Colder just hold it 5-10 seconds if the vehicle has sat for more than 6 hours without running. 24V to 12V plugs will probably work just start at 2 or 3 seconds on before cranking. You can also "split the batteries" for a non constant load like this on 1X vehicle start per day it will probably be just fine. Some direct injection engines do not need glow plugs at all for normal temperature operations.
