I think perhaps you are going on the correct route with putting one in the front first, given that you're going to school in Boone and drive the troopy on snow covered roadways. You are much more likely to break the rear end free turning on a slippery road with a locker in the back.Well, my parts got here after the sunset today, figured I might as well take the front diff out and throw a front Aussie locker in it. This is something I have been wanting to do ever since I first took the troopy to Uwharrie, then Moab, then Windrock, etc etc. I'm always at an obstacle thinking "man if I had a diff lock right now I wouldn't have to worry about panel damage or use the skinny pedal to get thru something"... solid axle in combonation with like 8 leaves doesn't allow for much flex. Manufacturers usually go for rear lockers and I see a lot more people put in rear lockers first I've wanted front for multiple reasons, especially since I knew I was going the auto locker route. I didn't really want to constantly have an auto locker clunking around, thus with free wheel hubs it'll only be active when my hubs are locked. here's just a bunch of words hob gobbled together off the Aussie Lokka website:
"A front fitment will actually yield the greatest improvement in off road ability. This is because, most vehicles require the increase in traction (that a locker gives) when hill climbing. Under hill climbing conditions, due to the angle of the vehicle, the rear wheels are carrying a much greater weight (weight transfer) and the front wheels are therefore carrying a lessor weight and tend to break traction more easily.
Once one front wheel starts to spin, the other front wheel stops turning and the front differential ceases to provide traction. At this point all power load is transferred onto the rear wheels as if it were a 2×4 and due to this increased load, the rear wheels are encouraged to spin and the vehicle stops.
If you can solve the problem of the front wheels losing traction, you have solved the traction problem.
Another advantage is that on road there are no changes to normal driving characteristics – assuming it has Free Wheel Hubs or a Disconnect Mechanism"
Man this thing is heavy!!!
I'm also working on rigging together a new intake, I've been worried about my duct tape intake collapsing or disintegrating metal air ducting into my turbo for a while now.
oldView attachment 3018359
new
Pay attention to your side play try to do it for recommendation when you put that locker in. I have a Spartan locker in the front of my bj-73. It doesn't unlock easily and steering is a bit stiff when the hubs are locked. It's stiff to the point where it's dangerous to drive on paved roads with front hubs locked in two wheel drive. You got to put some muscle on the steering wheel sometimes to break it free. This was never an issue with my samurai that had the lock right version of The "lunch box type" locker. Make sure you test this after you get it in before you run it off the road trying to go around a turn on a hard road with the front hubs locked. .................... If all is well it will still differentiate properly and you will have a lot better directional control on slippery roads and terrain then someone with an air locker or E locker in the front end.
Since you have locking hubs your front end probably does not have the wear that mine did with the original Toyota drive hubs. If you do have slack in your front drive line you can adjust a little bit of it out while you have it apart if it's not noticeable and annoying I wouldn't mess with it. If you watch a video on YouTube on how to set up a ring and pinion gear several times you can figure out how to do this even without a dial indicator you can sort of do it by feel. Albeit it's much better to have a $30 magnet Mount dial indicator to do this. Personally I can feel the difference between 10 and 20 thousandths " with my fingers.
