Builds The honey badger build (3 Viewers)
You already are set up for GM, just put a $300 5.3 in it with the stock PCM, you could do the whole thing for the cost of a Sniper or less
I agree with everything but the $300 part. Snipering an SBC makes no sense. You need the same fuel system upgrades to Sniper as if you were putting in a 5.3, so if you can find a complete 5.3 with all front accessories and paired computer, you just need to buy a standalone harness. If i could find $300 5.3’s id have one in every cruiser!
They’re $300 after you scrap/sell the $1k donor truck !
He already has a high pressure fuel system, and yes a aftermarket standalone harness makes it easier but it’s not hard to trim down the original harness. Lt1swaps.com will flash the PCM for $75.
$30 plates from Amazon could bolt it into his existing mounts.
If not on a super tight budget yes a $700 swap harness is nice
Going to put the hard top on. I think it looks better
Drove down to Summit today and exchanged my Sniper. For a Sniper 2 🙏. This is its last chance.
Get a Sniper 2 they said. It will be fun they said :bang: F this WTF Holley this is NOT plug n Play . Then the crap i need they dont even have yet. . Its official i hate this 40 :flush:
OK after i slept on it i called Holley first thing today and they were very helpful . So the new sniper does not plug into the old hyperspark ignition . Well it does but you need a diffrent harness ( they are sending me one for free ) The throttle cable braket is different and mine could maybe work but it would not be right so i ordered one. Will have tomorrow ( the sniper 2 is narrower than the 1 ) Since i have a returnless system ( they have not even sold a Returnless sniper 2 yet ). i need to just cap a line Easy . I think once i get it set up it will be really good , and much better than the 1 . i also ordered the 5 inch screen that also has gps speedometer . the Tech was telling me if i wanted to keep it looking vintage he had seen once that a guy took his mechanical fuel pump and hallowed it out . I said Holley should just make a Dummy pump but put the pressure Regulator in it :hmm: . And That idea is going to the next Meeting . So if you see this in the future you know were it came from :D. In fact i should make one and sell them to the hot rod guys :hmm:. I am not going for the retro oe look on mine :D
Whats Next ? well. i noticed i have a trans leak from somewhere ? i have not found where yet. so that needs to get fixed . Then i am putting the hard top on so everything for that. and finish my doors . I think i am going to tie my seats into the cage MT has the kit :hmm:. And bump stops i honestly can not feel the rear when its rubbing but can see where it is . I am going to make a New bumper also. without the grill gaurd i just think it would look cleaner :hmm:.
OK after i slept on in i called Holley first thing today and they were very helpful . So the new sniper does not plug into the old hyperspark ignition . Well it does but you need a diffrent harness ( they are sending me one for free ) The throttle cable braket is different and mine could maybe work but it would not be right so i ordered one. Will have tomorrow ( the sniper 2 is narrower than the 1 ) Since i have a returnless system ( they have not even sold a Returnless sniper 2 yet ). i need to just cap a line Easy . I think once i get it set up it will b e really good. and much better than the 1 . i also ordered the 5 inch screen that also has gps speedometer . the Tech was telling me if i wanted to keep it looking vintage he had seen once that a guy took his mechanical fuel pump and hallowed it out . I said Holley should just make a Dummy pump but put the pressure Regulator in it :hmm: . And That idea is going to the next Meeting . So if you see this in the future you know were it came from :D. In fact i should make one and sell them to the hot rod guys :hmm:.
Whats Next ? well. i noticed i have a trans leak from somewhere ? i have not found where yet. so that needs to get fixed . Then i am putting the hard top on so everything for that. and finish my doors . I think i am going to tie my seats into the cage MT has the kit :hmm:. And bump stops i honestly can not feel the rear when its rubbing but can see where it is . I am going to make a New bumper also. without the grill gaurd ijust think it would look cleaner :hmm:.
No grill guard and just bumper would be way cleaner imo.
How much do you have into the sniper ? just curious. I agree on the snout bumper, had it a long time, tired of it, curious to see what you come up with out front.
I think i have 3600 into all the sniper stuff . The sniper 2 did not cost me anything since they sent me a new Sniper unit i just exchanged it for the new sniper 2 . Yes. i will do a drivetrain swap. but i want to collect all the parts first And No it is not going to be 300 bucks to do it :D . I think i am going to tie the cage into the coilover crossover. . Oe has those 2 rods that go from firewall to Rad. so kinda like that just better Maybe make a sort of hoop that replaces the oe horseshoe rad mount
It’s a much cleaner looking unit . Will have the throttle cable brackets tomorrow 👍
My throttle cable brackets came today really cleaned things up. Just need to hook up some wires and I should be doing burn outs in the neighbors grass soon 😃
Houston we have HP 😃. I got her fired up today and it runs soooo much better . Took a little bit to get it dialed in but she is mean now . Now let’s see if it can stay this way . But it’s night and day different .
Been following your thread, and the nightmare youve been dealing with. Glad to see that it seems to finally be right. I dont think youre the only one with issues with it. I have noticed a lot of Snipers coming up on Marketplace in the last month or so.....
