I'd want to see dyno sheets for all these on an identical vehicle, tuned by the same person. If I was paying $2,500+ on a turbo (which I certainly am not), you'd bet your ass I'd want to see some additional, independent research.
I've seen more than enough dyno sheets now to know they mean very little to how a car actually drives on the road. They are useful tools for tuning and testing but from what I have found they give no real indication of how well that same vehicle will build actual speed on the road, provide quick transitions or early torque build. How often are you actually at full throttle while you are driving, the way the car reacts to part throttle loads comes more into play when out on the road and this is the area that gives you that drivability we are all after. Well at least I know that's what I'm after.
Sure I too like to get up and boogie and quite often rev it out to 4000rpm when I'm in the mood and it's nice to not have the power drop off like some other turbos do but that's not where this turbo shines most. It's all this on/off throttle and part throttle situations where I have found it to be far different to previous turbos and it's so much more enjoyable to drive. The rate at which you gain speed and close the distance to the car in front driving in traffic or overtaking out on the freeway with barely applying any throttle is really quite an eye opener. It does all this long before it's anywhere near full boost and this is probably the most noticeable change I've experienced. Normally I would have to have dropped back a gear or waited until I was back up to peak boost before I got the same increase in speed I now get with the current turbo.
