Suggested tools for new FJ40 owner (1 Viewer)
Will need one of these for sure
ok
ignore ALL the above post's even mine too please ,
this suggestion below is your #1 purchases , and most important day 1 tool in your BOX !
no kidding here , serious matter at hand
if anyone disagrees , please post your reasons why ?
without thee 2 exact FSM , Field Service Manuals your screwed ..............:confused:
that is straight talk you need to know now and understand
With only kind intentions ,
matt
Just standard tools, no metric stuff at all. I’ll admit I am not too mechanically inclined, but I do have to willingness to learn.
"These things are super easy to work on."
I heard this statement many times, but honestly it's very true. I would consider myself a novice mechanic at best, with a limited set of tools, and I've done some things that have surprised myself that I could complete the job. You'll learn a lot and really get to know your 40 and what it needs, which will make you better at fixing your own stuff and knowing how things work.
Get yourself a manual and find the resources online and you will be off to a great start. Just start doing things, that's the only way you'll learn. Good luck!
Correct me if I am wrong, but i do not think that the most important one of all has been mentioned yet?
And don't forget a good quality grease gun, extra grease and an oil filter wrench. It is handy to have on your workbench a jar of grease, and machine oil... A can or 2 of Brake Kleen and lots of shop towels. A little LED spot lamp that fits on over your head is nice to have as well.
Quality set of Metric tools (sockets, end wrenches) ranging from 6mm → 24mm that has a lifetime warranty from a retail store that is close to you that is also open on Sunday. (Husky, Kobalt, Napa, Craftsman).
54mm hub socket, though a 2-1/8 socket will work well too.
24 inch long 1/2" drive breaker bar
Set of socket adapters
Spiral sockets to help remove rounded off nuts/bolts.
Set of four 6 ton jack stands.
2 ton floor jack.
Digital Multi-meter
Vessel Tool set of JIS specific screw drivers.
Seal driver set.
Get a multimeter and test light, or spend big and get a power probe. A lot of PO's messed with the wiring and that will put a stop to the fun real fast.
Dyno
