Subwoofer Options... (5 Viewers)
That amp will move the sub, but looks like it may be on the end of being underpowered. That 400w max rating is utter BS. 60wx2 rms is the figure of actual power.
Some of the comments say it ran too hot with 2 subs... my guess is that it isn't 2 ohm stable, generally meaning not a very good sub amp.
There are a few more options for the power and price points.
https://www.amazon.com/dp/B00IEN271...TF8&colid=2FS00JU8STZA7&coliid=I3D2Y5EUJIBWK4
https://www.amazon.com/dp/B00BF6HY8...lid=2FS00JU8STZA7&coliid=I25EBOK4BBCC7Z&psc=1
https://www.amazon.com/dp/B0064N6CD...olid=2FS00JU8STZA7&coliid=I29PU99AHW7U6W&th=1
My 6" factory sub replacement.
full
full
Thanks for all the feedback guys, I'm going to continue looking at any further replies though, just in case I get anymore useful suggestions or feedback.
I just started building one around a set up that my Co worker has. An 8" infinity 800w max needs a .35 cubic ft sealed box. Then a precision power class D amp. His sounds great for a small clear bass adder in small spaces.
Next step is the fiber glass box behind it
I also need some feedback on how different positions would sound.. like I said, I heard that the woofer(s) in an enclosure facing the rear window will sound the best, but I'd like some more feedback :)
You will not get a club sound out of an 80.
There is a lot of noise pollution from outside which will interfere with your beats a lot. Even if you sound proof the hell out of it, it still wound not sound like a brand new Lexus.
Here is a spectrum recording I made of my setup from the front seats. Very clean and plenty of lows but I have a feeling you are wanting the base to slap you in the back of the head. You are more than welcome to drive up and check out my setup.
full
Any way I could get dimensions from you on the little 6" box and any other holes you put in it??? Thanks!!! :beer:
Since this thread got bumped, it reminded me I never updated it with what I ended up with. I did use the Rockford Fosgate PS-8, and I'm pretty happy with how it turned out. Certainly not huge amounts of bass, but much better than what it was before. (and MUCH better than the factory sub)
Subwoofer, factory location/hidden
I was just about to recommend powered subs. RF 12" looks nice.
I'm looking to upgrade the sound system in my Cruiser (92 FJ80) and I need to figure out my options for a subwoofer. I really don't know much about subwoofers and how they work or how much room they need, etc. to sound real good, but so far, I've figured out a few options.
  1. Put 2 8" shallow mounts in the tailgate facing the back of the rear seats when the tailgate is closed
  2. Remove factory 6" subwoofer and its bracket, replace with a bracket for a 10" subwoofer
  3. Get a subwoofer enclosure for a 10" subwoofer, install behind rear seats with woofer facing tailgate
  4. Get 2 8" and 2 enclosures, put at each side of the rear cargo area w/ subs facing roof
If anyone wants to know, I'm going to be installing 6.5" woofers (not to be confused with subwoofers) in each door in the factory mounting location, and I'm going to be drilling holes at the top of each door panel for 1" tweeters. I will also be getting an amp (or two, I don't know what I will need) and replacing the stock head unit with a Double DIN Kenwood HU. Any help is appreciated... thanks!
Do not go with option #1
Since I still use the original stock Lexus head unit, I went with a powered Bazooka strapped down in the cargo area. For thump that's surprisingly good, the price was great. And as old school as the stock unit may be, I love having immediate access to a physical knob to quickly adjust the bass for each song.
Fabulous, according to my taste.
You will never win any bass contest with it, but it complements the sound of the other speakers very well. It will not rattle your windows or rear view mirror. It simply adds what it was missing before.
In fact on my head unit I have the subwoofer sound down to level 3 out of 10.
I had to use a little more padding because at higher volume the speaker membrane would travel a little to much and touch the plastic panel cover which would cause vibration. The padding ended up increasing the distance from the speaker and the cover. No more touching, pure sound, distortion free (according to my ears).
Of course a 10" would be better than 8", 12" would be better than 10", 2 x 12" would be better than one 12". 3 x 15" would better than 2 x 12" etc, etc. It never ends.
Does my system need anything else?
Yes!
Replacement speakers for the OEM rear door speakers. Preferably 6.5"
Anything else?
Not really.
Maybe sound deadening material on the floor, doors and rear quarters.
Will I ever do that?
No way!
Is the box wedged in or attached in some way and what exactly do you mean when yuou say you added more padding to prevent rubbing? Trying to wrap my head arouhnd this.
The box is not attached to anything. It sits on a small piece of 2x4.
Padding... a sponge actually which increases the distance between the plastic quarter panel panel and the box, therefore creating more room for the sub speaker to travel without touching anything.
Above 50% volume on low bass note, it would touch the cover and create some vibration. I guess it has some long travel built in.
Now with more spacing I can crank it up without creating any vibration due to touching anything in its way.
This method creating a little more spacing between the cover and the car's body, maybe 1/4 - 1/2" gap. Maybe.
I did trim some plastic off the back side of the cover too.
The visual aspect is totally negligible and in no way reduces the trunk volume and capacity.
I simply did not want to have it inside the trunk, visible to anyone, bouncing around all the time (if not properly attached), or take away precious cargo room.
Maybe I lied a little. There is a little bulge on the bottom. A lot more apparent with the liner angled up.
